I think I'm regretting the Eibach Springs!!!
Old Aug 26, 2005 | 08:42 PM
Chris's Avatar
Hey folks, I just got back from the body shop, the Greddy/Kenstyle body kit is on (both authentic). No fitment problems at all!! It's getting painted tomorrow. I'm so happy...but....
This thing is sooooooooo low!!!!!! I have the Eibach springs and combined with the Greddy front bumper, this thing sits like 3" off the ground! I can't even clear the driveway getting out of the body shop!!
What springs can I get that will lower the car only .5"?? I will trade someone for other springs that will only give me a .5" drop or I'll buy if someone has something laying around. I need them by next Thursday.
Thanks guys and gals!
~C
Old Aug 26, 2005 | 08:47 PM
jjyellow's Avatar
Try Tein H springs
Old Aug 26, 2005 | 09:25 PM
ducatiguy's Avatar
Premier Dough Slapper
You think that's low? I'm running 1.75" Sprints with Greddy front & sides and Kenstyle (replica) rear... I swapped out my 19" for 20" just for the raise...
Old Aug 26, 2005 | 09:36 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
350Z springs will drop you .5"
Old Aug 26, 2005 | 09:50 PM
Triple8Sol's Avatar
Eibach is not that low...unless you're running the Z version. There are much lower springs out there.
Old Aug 26, 2005 | 10:34 PM
accordfreak's Avatar
I had my tein basics set at stock height.
Old Aug 26, 2005 | 10:39 PM
kenchan's Avatar
the prokit lowered the front and rear about 1.4" when I tried it out. im using the rear's right now, they look fantastic on the car. front, im running s-techs.
Old Aug 27, 2005 | 03:25 PM
MikeyMike's Avatar
Rollin On Dubz
Do you know how to drive a dropped car? You have to go up and drown driveways at an angle...one tire at a time from left to right, or vice versa.
Also when you park, be mindful of those concrete blocks in front of parking spots..if you go too forward you'll scrape.
Old Oct 7, 2005 | 07:41 PM
Patentmat's Avatar
I scrape those concrete things in the front of parking spaces stock
Old Oct 7, 2005 | 09:36 PM
Napoleon's Avatar
+1
S.
Old Oct 7, 2005 | 10:13 PM
mephistomyhero's Avatar
+2!
Old Oct 7, 2005 | 10:52 PM
supag116's Avatar
~C
Are u using Eibach pro-kit or Sportline?
Old Oct 8, 2005 | 03:10 PM
G35SHAWN's Avatar
That's funny, the prokit only gives 1inch drop.
Old Oct 8, 2005 | 03:15 PM
MikeyMike's Avatar
Rollin On Dubz
It says 1 inch on the box...but it "settles" at about 1.5.
Whatever a drop claims...add another half inch at least.
Old Oct 8, 2005 | 05:04 PM
dklau33's Avatar
Agreed. OEM 350Z springs will drop the coupe about 1/2". Just be aware there are two different spring rates for the rear. All OEM 350Z front springs are 314 lbs/in. The rears come in 342 lbs/in or the revised higher rate springs are 427 lbs/in. These numbers come via our resident suspension guru G35sedan.
DRG35R
Jan 31, 2016 07:14 AM
