HELP! - Tokico 350z D-Specs Shock Install
Old Sep 24, 2005 | 10:37 PM
wingnut's Avatar
I'm in the middle of installing springs and shocks and I'm in need of some help (this is my first attempt at something like this, so please forgive any stupid questions). I'm working on the rears and the springs have gone in fairly easily but I'm not sure how tight/far down I'm supposed to tighten the piston rod top nut on the shock. I've transfered over the dust cover and rubber bumpers/spacers and mounting bracket from the original shocks to the Tokicos. The Tokicos came with 2 nuts of different thicknesses and I'm not sure how far down the threaded shaft I'm supposed to go? Am I supposed to use both nuts - one to lock the other one down? Should I measure the amount of threaded shaft so they're both the same on both shocks? Help please! I've attached a photo that shows the shock and one of the nuts partially on the rod with the other on the ground next to it.
And yes, I realize it's 7:40PM on a Saturday and I have absolutely no life.
Thanks in advance.
Old Sep 25, 2005 | 03:59 AM
kenchan's Avatar
You can hold the piston shaft with a monkey wrench or a small box wrench and hand tighten the larger nut you show already on the shaft. it does not need that much torque. Just hand tighten...like i donno...35ft/lbs? (just my guess).
Then the smaller nut you can use to lock the larger nut in place. just hand
tighten. don't use an impact gun.
Old Sep 25, 2005 | 04:01 AM
kenchan's Avatar
btw, the purpose of that nut is to hold down the top mount snug. it can not have any play or you will get rattling. just hand tighten and you're set. don't over tighten
it as your monkey wrench could slip and damage the threads on the shaft.
Old Sep 25, 2005 | 04:54 AM
wingnut's Avatar
Thanks Ken!
Old Sep 25, 2005 | 06:15 AM
supsup's Avatar
what springs are u putting on?
let us know how is the performance
Old Sep 25, 2005 | 09:38 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
FWIW..
I didn't use the supplied nuts, don't really like double nutting.
I used a nylock nut, which are self locking.
Old Sep 25, 2005 | 10:30 AM
kenchan's Avatar
no prob, wingnut.
inTgr8r- yep, that'll work too. or you can put a dab of threadlock-blue on
just the one larger nut.
it's up to you how to do it.
Originally Posted by inTgr8r
FWIW..
Old Sep 25, 2005 | 10:58 AM
wingnut's Avatar
I'm putting on RSR Ti 350z springs. I'll have pics of the full install and my analysis of the performance difference with this setup in the near future.
Old Sep 25, 2005 | 11:00 AM
wingnut's Avatar
FWIW..
I think I might try that - using the nylock nut off the factory shocks. I wasn't all that crazy about the two nuts either. I'll let you know how it goes. Thanks everyone for your input.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
snic09
Nov 8, 2017 01:46 PM
nosam1g
Aug 22, 2015 11:58 PM
linedr89
Aug 17, 2015 05:11 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
