Unusual situation and fitment question... is this ok?
Old Sep 29, 2005 | 07:37 PM
dklau33's Avatar
Okay this situation is a bit funny so bear with me. I have two sets of wheels. FN01R-C 17x8 +42 for the street. Stock Mitsu EVO Enkei wheels 17x8 +38 for the track. Let's say one day down the road I'm going to get a front Stoptech 13" kit. Let's say that my FN01R-C wheel won't clear the Stoptech caliper but the stock EVO wheels fit just fine. Now in order to make the FN01R-C fit I need to use a 5mm H&R spacer with longer bolts. Let's also assume that the stock EVO wheel will rub the outside fender if I put it on with the H&R spacer. So lets say I put the stock EVO wheel on without the spacer but still with the longer bolts from the 5mm kit. My question is will I still be able to torque down the lug nuts all the way on the EVO wheel since the hub bolts are longer? I'm assuming it will be fine since the bolts aren't too much longer.
Old Sep 29, 2005 | 09:02 PM
baileyrx's Avatar
as long as the lug nuts are open ended. otherwise the stud might/will "bottom out" on the nut
Old Sep 29, 2005 | 10:37 PM
dklau33's Avatar
That's what I was afraid of. Guess I might have to get a set of open ended lugs just for the track days. Thankx.
Old Sep 29, 2005 | 10:40 PM
sen_jen's Avatar
Meatshake Enterprise
yeah, whenever you use extended studs, open ended lugs are highly recommended.
KruZZe
Feb 27, 2023 05:04 PM
the93owner
Oct 4, 2015 09:40 AM
Jeff T
Sep 30, 2015 02:00 PM
JustinMKN1
Sep 18, 2015 03:40 PM
