Lug got stuck to lug wrench...help!
Is the stock lug wrench even the correct size for the stock lugs? I removed one to install wheel locks and the lug got impacted to the wrench! I never had this happen before.
yes the stock lug wrench is the correct size for the stock lugs.. but they aren't the easiest things to use.. i use the wrench that comes with my jack and it's 10 times easier to use..
Turn it back on to the stud but don't tighten it. Then rock the wrench back and forth a bit. Finally, remove nut. At this time you can even use the lug wrench to remove it and it won't stick because there shouldn't be any pressure.
I don't have any idea about the size issue though.
Curt
Curt
seagrasser
May 3, 2022 09:43 AM
