Will these fit on a sedan?? Help please
Old Oct 12, 2005 | 02:30 PM
MikeyMike's Avatar
Rollin On Dubz
Will these fit on a sedan dropped with the Eiback pro kit, which is about a 1.5 inch drop.
19/8.5 FRONT 19/9.5 REAR (+45 off sets)
BTW, Search function does not work at this time which is why I ask.
Thanks guys
Old Oct 13, 2005 | 02:25 PM
JOES14's Avatar
Yes, they will work fine. The guys over at www.revhighonline.com actually sell 8.5 up front, and 10 in the back, and it works fine with a lowered G!!
Old Oct 17, 2005 | 06:48 PM
MikeyMike's Avatar
Rollin On Dubz
On a 4 door G? Not the coupe.
Old Oct 18, 2005 | 12:52 AM
G35Lin's Avatar
Multi-Spoked Mod
hm.. i believe that
+38 8.5 and +42 9.5 are the best offsets
ed
Old Oct 18, 2005 | 02:58 AM
skeleton_cru's Avatar
Sedan
Thanks guys
The rear is fine, but the front will be tucked in a bit. You may want to consider 5mm spacers for the front to make the offset +40.
Old Oct 18, 2005 | 01:57 PM
05Blk's Avatar
can he go 275 in the back?
Old Oct 18, 2005 | 02:46 PM
Gsedan35's Avatar
We have two high profile members here with sedan's and 9.5" wide rims with 42mm offsets that had rubbing problems with 275's. To have to pick a certain tire because it has curved shoulders or to run excessive negitive camber is a absurd way go. On 9.5" width's, if you have any plan's on running 275 sized tires, go with at least a 45mm offset. Unless you have already found a reliable shop to roll your rear fender lips in advance.
Old Oct 18, 2005 | 02:58 PM
Gsedan35's Avatar
I agree.
In the picture below, note the clearance with a 18x8 wheel with 45mm offset and a 245/45-18 tire. Increaseing the wheel width to 8.5" would decrease the clearance from the tire/wheel to the suspension upright by a 1/4"
Old Oct 18, 2005 | 03:06 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by Gsedan35
I agree.
^^WHS^^
I have 8.5 +42 on the front & its right at the limit.
Only 2 -3 mm clearance; any more def requires spacers.
Old Oct 19, 2005 | 12:33 PM
trebien's Avatar
I'm looking at getting some 8 or 8.5" width rims and tires (255/265 max)...
So what offset is recommened for this size rim? These would be either 17" or 18" rims - for track use. 2005 sedan.
Old Oct 19, 2005 | 01:06 PM
court's Avatar
im ordering 8.5 frt 245 and 9.5 275 rr, not sure what offset yet but gonna get the most agressive possible, what do others have(offset wise) most agressive?
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
ohitstruee
Aug 7, 2015 04:59 PM
teamghost
Jul 28, 2015 04:52 PM
joedaddy1
Jul 28, 2015 02:58 PM
