camber? a simple yes or no please...
Old Oct 12, 2005 | 05:15 PM
AntRock's Avatar
Is our front camber ajustable?
Old Oct 12, 2005 | 05:21 PM
symalik's Avatar
no pretty sure its not
Old Oct 12, 2005 | 05:56 PM
dklau33's Avatar
Not without an aftermarket upper A-arm that has camber adjustments.
Old Oct 12, 2005 | 06:20 PM
ducatiguy's Avatar
Premier Dough Slapper
No, not in stock form... Yes, if you go with aftermarket A-arm setup...
Old Oct 13, 2005 | 11:02 AM
ISMSOLUTIONS's Avatar
The is only toe and caster for front and rear on these cars.
Old Oct 13, 2005 | 11:42 AM
Cactus's Avatar
Is the G35 the only car you have to spend as much for parts as the supension itself to get the correct numbers?
Old Oct 16, 2005 | 09:36 AM
dcreigh1's Avatar
The camber in stock form is not adjustable. However, there are aftermarket bolts that can be used to allow a +/-.5 deg change. This is used in many cases when front end damage is repaired. How else do you think these body shops correct camber issues? They don't go out and buy an adjustable A-arm, they just put in these eccentric bolts and re-align the suspension.
Old Oct 16, 2005 | 10:03 AM
As far as I have researched - this is not true. I have spoken to someone at a frame/alignment shop, whom I've known for about 18 years, and these cars will require either frame pulls and/or new arm purchases to re-adjust camber after a hit....or the aftermarket arms that are adjustable.
Cars that have the adjustments to begin with can use longer bolts, aftermarket, to make further adjustments over stock, to forego frame alignments or expensive parts replacments.
Old Oct 17, 2005 | 04:26 AM
skeleton_cru's Avatar
Sedan
Sounds like shady practices to me.
Old Oct 17, 2005 | 01:47 PM
OvaYahead's Avatar
no.
Old Oct 17, 2005 | 04:53 PM
sapzil's Avatar
what if we dont fix the camber after lower the car over an inch????
Old Oct 25, 2005 | 04:01 PM
IAPDirect.com's Avatar
You will highly regret it. You will eat through tires much faster than you want. Its either spend the money now on camber kits or spend much more money later on camber kits AND tires. If money is an issue, at least do the rear camber kits as they are much cheaper than the front kits. Check out www.camberkit.com for the rear kit for your vehicle.
PM me if you have any questions.
-Peter
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Rose M
Oct 12, 2015 10:00 AM
