Widest Tire To Fit 10" Wheel?
Old Oct 26, 2005 | 02:03 PM
BrianlG35C's Avatar
Ohio G Club Member
I want to go as wide as possible on my rear 20x10" DPEs with or without rolling my fenders. Does anyone know the max I can go?
Old Oct 26, 2005 | 02:49 PM
sen_jen's Avatar
Meatshake Enterprise
well, for stock height, you can run up to a 295. however, not in all brands. some are made fatter than others. i think a 285 would be better. but that sidewall is gonna flex.
Old Oct 26, 2005 | 02:54 PM
Alan's Avatar
i think the answer to that question also depends on your offsets and how low you are. i would say a rough estimate would be max 275 if you are lowered.
Old Oct 26, 2005 | 03:05 PM
caskyline's Avatar
Former Vendor
I have 285 x 30 x19 on my 19 x 10's. 15 offset 4" lip.Lowered 1 1/4" with camber kit. No rolled fenders.And I still don't rub.Hope this can give you some reference.
Old Oct 26, 2005 | 05:25 PM
BrianlG35C's Avatar
Ohio G Club Member
Thanks for the help guys but I'm already running 285/30s in the rear but I want to go wider. What I need to know is what size will safely fit on a 20x10" rim, regardless of trimming/rolling the fenders.
I need better traction for TTs.
Old Oct 26, 2005 | 07:09 PM
CreativeAutoworks's Avatar
brian, try a sticker tire then the GRB's such as the KDW's, PS2, or S03's all are made in the 285/30 20, all also make a 245/35 20 for the front.
james
Old Oct 26, 2005 | 07:13 PM
sen_jen's Avatar
^ yeah, of those listed, try to SO3's. reason is because it provides better clearance with the fenders.
Old Oct 26, 2005 | 08:50 PM
BrianlG35C's Avatar
Ohio G Club Member
Thanks James I will consider but will 295s or 305s fit my 10s?
Old Oct 26, 2005 | 08:52 PM
JDM 350GT's Avatar
dang...i remember seeing 305 on Z's rear but i dont know if its 10...
Old Oct 26, 2005 | 08:53 PM
baileyrx's Avatar
315's will fit.
thats my next tire after i get my rims widened.
i currently have 275's on stock 8 in rims,
8---> 10in will yeild 50mm increase in width
so 275mm + 50mm= 325! it's even less drastic than my current set up
current setup has bee n great for just about a year.
look for threads about it under my name
Old Oct 27, 2005 | 05:19 AM
wayneside's Avatar
285/30/20 is what we put on a friends G35 on some 20x10's...work great...
Old Nov 25, 2005 | 09:00 PM
SWAT311's Avatar
I just put a 285/30/20 on my 20x10 wheel and I'm gonna have to roll my fenders. I know this is almost a month old, but just some added info.
Old Nov 28, 2005 | 11:21 AM
BrianlG35C's Avatar
Ohio G Club Member
Hmm, I've had Falken 285s on my 20x10s with Tein H-Tech springs for a few months now without rubbing. I'd like to go 295s if possible. What brand of tire are you running??
Old Nov 28, 2005 | 03:29 PM
SilverII's Avatar
anything past 275 = big money....
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
JaeXL
Aug 4, 2015 07:43 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
