Lugnuts and tire sizes
Old Oct 28, 2005 | 12:15 PM
speedgeek's Avatar
Hi,
Two Questions.
1. Will the lug nuts from my stock 2005 19” rims seat correctly on my 2005 350z 17” winter rims?
2. For the folks w/ 350z 17” rims what tire size did you get when going from 19’s to 350z rims for winter. Tire rack recommends 225/50 up front and 235/50 out back; I want to make sure my VDC doesn’t go off
Thanks!
Old Oct 29, 2005 | 11:13 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Lug nuts are the same on all our cars, g35 coupe, sedan or 350z so yea, they'll work. Tire rack is giving you the stock tire sizes so it should be fine with your vdc. If you want to get the tires to the closest size of your stock 19's go to www.tires.com and click infocenter. Go to "tire dimensions made simple" and enter your numbers. You should be able to find something close enough to stock.
Old Oct 30, 2005 | 12:35 PM
speedgeek's Avatar
THANK YOU!!!
Old Oct 31, 2005 | 10:29 AM
speedgeek's Avatar
Thanks again, great program. So...
For the Fronts I'm thinking of 215/55 17 and rears 225/55 17, the closest matches w/ the tire calc.
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
