maxima rims on a coupe?
Old Nov 2, 2005 | 01:04 PM
official_style's Avatar
i have and 04 coupe, with the 18s, and i was wondering if i could get a set of 17" maxima rims for the winter, and just slap on some snow tires? i belive my car has the staggered rims on it now, but having the same width all around shouldnt be a problem right?
Old Nov 22, 2005 | 01:37 PM
cmon NOBODY knows?!?!?
Old Nov 22, 2005 | 01:39 PM
MikeyMike's Avatar
Rollin On Dubz
DO you have brembo's? If you don't, I think it should be ok.
Old Nov 22, 2005 | 01:41 PM
JDM 350GT's Avatar
think it should be ok (i have 02 maxima)
according to the numbers i see...should be fine.
Old Nov 22, 2005 | 05:16 PM
codeflux's Avatar
offset is wrong for the maxima rims on a coupe. it'll rub.
Old Nov 22, 2005 | 05:38 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
What is the offset??
Old Nov 22, 2005 | 05:43 PM
axiochris's Avatar
i wonder hwo that would look..??
not a bad idea thou, for winter- time
Old Nov 22, 2005 | 07:05 PM
ok, so i am gonna buy some winter setup from tire rack. now when i was asking at the dealership about winter tires, they said that i will have a problem with the tire pressure monitoring system. they told me that i will have to buy infiniti rims from them, otherwise it will set off the tire pressure system. i didnt belive this. can someone confirm?
Old Nov 22, 2005 | 07:06 PM
GEE35FX's Avatar
I think the offset is ... +40mm
Old Nov 22, 2005 | 08:39 PM
InTgr8r's Avatar
In that case should fit OK unless Brembo equiped.
Unless I'm missing something....
Old Nov 22, 2005 | 09:01 PM
codeflux's Avatar
maxima offset = +40 if i'm not mistaken.
coupe offset = +23
the maxima wheel would sit too close to the fender and will rub. or is it - too close inside and rob on the shocks?... hm...
Old Nov 22, 2005 | 09:05 PM
InTgr8r's Avatar
+40 is tighter to suspension & clears no problem
Old Nov 23, 2005 | 12:13 AM
and what about the tire pressure monitoring crap?
Old Nov 23, 2005 | 06:31 PM
vq35max's Avatar
ok guys i am new to this forum but i have been a long time member at maxima.org. currently i work at a nissan dealership as a tech and i decided to answer your question about the tire monitor system. the way that system works is the monitor is programmed using consult 2 and it can be programmed to any wheel/tire combo. the monitor itself can be removed and it can be put on any rim even aftermarket rims. also i have a set of 4 rims from a 2004 and up maxima. the size is 245/45/18 with about 94% thread life on them and they are for sale. offset is 40 and they can be put on a g35 just like g35 rims can be put on a maxima. hope that helps.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
BlackGee35
Jul 31, 2015 11:04 AM
BlackGee35
Jul 23, 2015 01:36 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
