Will 285/35/19 fit rear and 255/35/19 fit front?
Old Nov 10, 2005 | 02:35 AM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
I'm going with the BFGoodrich g-Force T/A KDW-2 tire and I have 19" PIAA Super Rozza's on my car now...the front rim is 9" wide while the rear is 10"...will I have ANY issues with the tire rubbing on the inside of the wheel well?
Old Nov 10, 2005 | 11:33 AM
afr0puff's Avatar
Supa Dupa Moderator
Your fronts might rub on full lock turns. That only happens to me in a parking deck situation. 10.5 on the rear will rub definitely with those tire sizes without rolling. Not sure about 10".
Old Nov 10, 2005 | 04:19 PM
RashMan1450's Avatar
255 i think is a lil to wide. For the rear i think it should be fine.
Old Nov 11, 2005 | 08:29 AM
SilverII's Avatar
I am running 245/35 & 275/35 not dropped and I can see plenty of clearance for me to go bigger. I plan to go 255/35/19 and 285/35/19 once this T1-R wears out. My et is 24 front 23 back
Old Nov 11, 2005 | 12:17 PM
a.k.a. RANDYS_G
I decided on the 245/275 combo...don't want to risk it...went with the Goodyear Eagle F1 GS-D3's this time...better rated than the BFGoodwrinch KDW2 and Bridgestone S03's...we'll see.
Old Nov 11, 2005 | 12:56 PM
TINMAN's Avatar
what about 245/35/19 and 285/35/19 combo Randy?
Old Nov 11, 2005 | 02:42 PM
a.k.a. RANDYS_G
I didn't want to risk the tire rubbing in the rear since I have such an aggressive drop...also, the more staggered the front/rear is, the more understeer you'll feel. If this was only dragged, I'd go with what got more tire to the ground, but because I road race alot, i wanted a more balanced set-up. This is my happy medium.
Old Nov 12, 2005 | 08:53 AM
neffster's Avatar
Darn, I saw this too late. I'm running 255's on the front with NO PROBLEMS on my PIAA's.
I'm dropped about .75" in the front too. I've had my rear fenders rolled (shaved and painted actually) in hopes to be able to clear the 285's but I don't think that's doable with our aggressive +25 offset and any sort of a drop without a camber/toe kit (which I finally have now).
If you play with your rear camber I bet you can get 285's to work. Positive camber pulls in the tire from the bottom. This also makes the top of the tire come INTO the wheel well a little. Too bad you already went 245/275...
Old Nov 13, 2005 | 03:46 AM
nwrzG35's Avatar
i got 285-35 in the rear on a 10.5 and i have no rubbing issues
Old Nov 13, 2005 | 04:51 AM
peter_c's Avatar
i am running 275/35/19 and 295/30/19 with +35 offset f&r on tein s-tech.. no problems at all
Old Nov 13, 2005 | 09:10 AM
JDM 350GT's Avatar
what about michelin pilot ps2?
Old Nov 13, 2005 | 11:03 AM
a.k.a. RANDYS_G
thanks guys...tires have been ordered and should be here Monday.
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
