Another fitment question on sedan; 18x8.5, +38mm offset in rear
Old Nov 11, 2005 | 12:49 AM
trey.hutcheson's Avatar
Before anybody asks, yes I did do a search. I could't find anything that specifically addressed this particular offset. Either I'm stupid(likely), or it's not been discussed(unlikely).
I've just about decided to purchase a set of Kazera KZ-A's for the sedan. On tirerack, they have the 18x8.5 listed, with an optional 18x9.5 for the rears. The 18x8.5's are listed with an offset of +38, while the 18x9.5's are listed as +45. I really don't want to do the whole staggered approach, so, can I use the 18x8.5's +38 on the rear as well? I plan on using 245/40/18 series kumho's all around. Also, I have replaced the suspension with a set(shocks plus springs) from an 04 coupe, so I will have a slight drop all around.
Since I really just don't get the whole fitment issue, especially with offsets, I wanted to make sure I checked with the experts prior to making the order.
thanks
Old Nov 11, 2005 | 12:51 AM
skeleton_cru's Avatar
Sedan
thanks
Jeeez, just asking an offset question takes you three paragraphs.
YES! The 8.5, +38 is perfect front and back and the tire size is great as well.
Old Nov 11, 2005 | 09:16 AM
thx
Old Nov 11, 2005 | 09:36 AM
Chico's Avatar
Like Skeleton said it is a perfect set up.
Old Nov 11, 2005 | 10:17 PM
Ok. I'm wordy. Live with it. I obviously do
Actually, before I posted, I found the fitment chart, as well as other *related* posts. From all indications, the setup I was going for would work fine. However, I saw all kinds of people(especially when talking 19's), recommend going up to +45 offset if the car was lowered. Mine is, to a very small degree. So before I wasted a bunch of money, I wanted to make sure.
Old Nov 11, 2005 | 10:23 PM
While we're on the subject, what do you guys recommend for tire sizes? For the first set of tires, I plan on running 245/40/18's all around. In the future, I'd like to possibly go up to 255/40/18's all around. So, here are my questions:
1 - Will 255's fit on an 8.5 in wheel? From what I can determine, I believe it will.
2 - Will 255's fit up front with the coupe suspension and the +38 offset?
3 - I understand that putting 255's up front will affect handling, feel, and steering effort. Going from my curren 235/45's to such a size, would the effects be marginal or prominent?
Before anyone asks, I've considered a staggered setup but ultimately I want to rotate my tires using traditional methods.
Last edited by trey.hutcheson; Nov 12, 2005 at 01:03 AM. Reason: Misquoted tire sizes
Old Nov 11, 2005 | 11:24 PM
Teeter's Avatar
While we're on the subject, what do you guys recommend for tire sizes? For the first set of tires, I plan on running 245/40/18's all around. In the future, I'd like to possibly go up to 255/35/18's all around. So, here are my questions:
Can't answer all of this, but why "35" profile tires? They're about 5% small off the OEM size - much too much, I think. 255/40/18's (or even 265/40/18's) are almost perfect? -T
Old Nov 12, 2005 | 01:03 AM
Sorry, that was a misprint. I intended to use 40's, not 35's. Poor memory(Editing previous post right now). Thanks for the heads up on 265/40's. Didn't try that size(using the calculator on miata.net). Appreciate it.
Old Nov 12, 2005 | 02:08 AM
Chico's Avatar
1 - yes it will
2 - yes it will
3 - depends on what you mean by marginal and prominent. Better way to ask is...will you notice it?...the answer is 'yes'...larger mass = more steering effort.
I would stick with 245/40/18 all around for best handling and performance.
Old Nov 12, 2005 | 09:38 AM
Sedan
And so does Cheryl.
Old Nov 12, 2005 | 11:10 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I'm running 18-8.5" front & rear.
I went from 245 to 255.
The 255s are great.
Handling is great & no noticable change in stearing effort or feel.
They are closer to standard OEM size (DIA).
I noticed much better behavior out of the VDC; much less intrusive
Also the 255s sit nice & square on the 8.5" rims
Old Nov 19, 2005 | 11:04 PM
codeflux's Avatar
The 255s are great.
i have 18x8.5 rims with 245/40-18 tires... having read your post, i think i'll be getting 255-40/18 tires next time i'm getting tires. thanks dude!
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
teamghost
Jul 28, 2015 04:52 PM
joedaddy1
Jul 28, 2015 02:58 PM
Soumilg
Jul 18, 2015 12:33 PM
