how to take off the lug nuts?
Old Dec 15, 2005 | 05:04 PM
stylez09's Avatar
sounds like someone torqed your lugs way too tight...but with enough force you should be able to loosen the lug nuts...put your weight into it
Old Dec 15, 2005 | 05:07 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
You need to loosen B4 you lift the car (slightly)
Then you can lean right into it.
Old Dec 15, 2005 | 05:08 PM
stylez09's Avatar
what he said
Old Dec 15, 2005 | 05:16 PM
InTgr8r's Avatar
Originally Posted by smokedhen
am I suppose to have the car lifted before I try to unscrew the lugnuts? it is suppose to be counterclockwise right?
Loosen 1/2 turn or so with the wheel on the ground...
Lift it then remove the rest of the way
& yes turn CCW
Old Dec 15, 2005 | 05:29 PM
akrus's Avatar
First off, lower the vehicle so the tire is on the ground. Next, take a socket, slightly larger than the size of the one you use on the actual lugs, wrap a shop rag over the open end, slide it over the lug, then with a hammer, give the other end of the socket a sharp rap. Do this to each of the lugs and then you should be able to take them off without much further problem.
Basically, you want to break the seal between the lugs and the wheel. I've seen this work on junk yard heaps that have had their lugs seized on for ages.
Remember that you don't want to go at the wrench with too much torque because you definitely don't want to snap a lug. That's just a pain to have to go to a shop and press in a new stud. With the steps I gave above, you'll be surprised how easily the lugs will come off.
Also, get a quality torque wrench (ask for one for Christmas...), put it in the trunk and make sure that you use it whenever you get something done that involves removing your wheels. Don't trust shops to torque your lugs properly.
Good luck.
Albert
Old Dec 15, 2005 | 05:30 PM
booger's Avatar
Dude ...sorry , not trying to be mean . But if you cant remove a tire . Take it to a tire store and pay some one to do it . And dont touch your car again . Pay some one to work on it from now on .
Old Dec 15, 2005 | 05:40 PM
roneski's Avatar
Devil's Advocate
Invest in a breaker bar.
Old Dec 15, 2005 | 09:06 PM
kenchan's Avatar
smokedhen- sears has some nice 1/2" drive wrachet with long handle
and breaker bar (which you shouldn't need to remove wheel lugs).
get a metic deep socket set and you're all set.
Old Dec 15, 2005 | 09:08 PM
kenchan's Avatar
tirerack sells cheap torque wrenches for like $30, get one it'll save you
from over torquing your lugs.
remember to re-torque your lugs after driving 10-15miles.
good luck.
kenchan's Avatar
you can use 80 or 90lbs/ft. i use 90.
