Wheel Spacers Installation
Old Dec 30, 2005 | 05:03 PM
excel's Avatar
I received my 15mm Kics Project Spacers but the manual is in Japanese and I need to know how much torque should be used for the lugs.
Thank You
Old Dec 30, 2005 | 05:20 PM
RashMan1450's Avatar
by any chance, do you have any pics of the spacers?
Old Dec 30, 2005 | 05:36 PM
kenchan's Avatar
excel, i replied to your PM.
Old Dec 30, 2005 | 05:37 PM
kenchan's Avatar
here's a generic pict from www.optionimports.com
this is where i got my set. i bought 2 pairs from them.
very cool shop.
Old Dec 31, 2005 | 04:09 PM
firefox's Avatar
If I remember correctly the instructions said 102 N-m which is 75 ft-lbs. Just tighten it onto the existing bolts in a "star" pattern as if you were putting on a wheel. I was having some vibration problems at certain speeds, so I also got the 15mm hubcentric ring if you want to keep your wheels on the hub.
Old Dec 31, 2005 | 04:30 PM
kenchan's Avatar
i calculated to 78lbs/ft but close enough. lol...
yeh, www.optionimports.com has the hub rings for the Kics too. they are a perfect
fit.
Old Jan 1, 2006 | 06:13 PM
Dan_K's Avatar
Are these hub centric spacers?
Old Jan 2, 2006 | 01:52 PM
kenchan's Avatar
they sell the centering rings separately. $25 for the pair of rings.
Old Jan 3, 2006 | 06:38 PM
excel's Avatar
Another question?
Should the alignment be done with the spacers installed or not?
Thank you
Old Jan 3, 2006 | 10:42 PM
kenchan's Avatar
yes and no.
yes if you encounter too much tramlining or adverse tracking issues
with the wider track from the spacers while going over mild bumps and
dips. or, you get rubbing.
no if you don't feel any difference in straightline performance.
but if you're going to be using the spacers from now on, just put them on
and get the alignment done.
jsimonk
Dec 22, 2023 03:49 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
