will these tires fit on my 20s
Old Dec 30, 2005 | 10:40 PM
ebuy929's Avatar
Talking will these tires fit on my 20s
hey i have zennetti fives on my g with toyo tire
my dimensions that i have now are
front: 245 x 35 x 20
back: 275 x 30 x 20
i need new rear tires and i was thinking 275 x 35 x 20
please help
happy holidays
Old Jan 1, 2006 | 07:07 AM
g35doc's Avatar
They'll fit but you know your front tires are also the wrong size, right?
Old Jan 1, 2006 | 12:57 PM
k67p67's Avatar
I'm running 245/35/20 & 275/35/20 on 8.5"/9.5".
Old Jan 2, 2006 | 01:54 AM
ebuy929's Avatar
why is my front bad (245 x 35 x 20)
right now i have:
245 x 35 x 20 ........ 8.5" offset........ .front
275 x 30 x20........... 10": offset........rear
my question was if 275 x 35 x 20 would be good in the back
and what wrong with my current fornt setup
Old Jan 2, 2006 | 01:57 AM
G352NV's Avatar
Never enough
Perfect 245/35/20 275/30/20
Old Jan 2, 2006 | 10:37 PM
ebuy929's Avatar
and as mentiond b4 whats wrong with my front setup
Old Jan 3, 2006 | 01:04 AM
Sponger's Avatar
6MT Brembo Coupe
I have 275/35/20 with Z h-techs and it doesn't rub. Also keeps the VDC happy.
Old Jan 3, 2006 | 01:58 PM
ebuy929's Avatar
thanx does the offset make a diffrence on the size cuz my rear 10 in ch is big
thanx again
Old Jan 3, 2006 | 02:00 PM
ebuy929's Avatar
also can anyone post pix of the fitmant and how tries of these dimensions look on the car
Old Jan 4, 2006 | 02:13 AM
ebuy929's Avatar
i wanna go 245 in front and 275 in rear i want as much tire sidewall as possible
i have 10" rear and 8.5" front rim what dimensions should i get for my tires
keep in mind i want as much tire as possible to increase the protection of my rim and softness of the ride
please help my tires are shot
Old Jan 5, 2006 | 10:08 AM
Sponger's Avatar
6MT Brembo Coupe
I'm running 245/35 and 275/35 with the same width rims. You'll be okay as long as you're not too low and the offsets aren't too aggressive.
Old Jan 5, 2006 | 02:27 PM
ebuy929's Avatar
my front wheel is 8.5 inches
my rear is 10 inches are you sure 275/35 wont rub at all
Old Jan 6, 2006 | 12:49 AM
Sponger's Avatar
6MT Brembo Coupe
Let's try this again. I have 8.5" fronts and 10" rears with 245/35 and
275/35. It will depend on your offsets and how low your car is.
Old Jan 7, 2006 | 06:14 PM
ebuy929's Avatar
winters here and so is salt on the streets, i have alot of camber on my toyos ti-s i dont wanna buy new wheels and then destroy them in the winter
anycase regardless of my situation i know that the toyos are directional but would it be possible to swap the tire from my :
left front wheel and put it on my right front wheel and ride on it for a little.
the outside of my tire says right on the sidewall but does it say left on the innersidewall of that same tire?
Old Jan 7, 2006 | 08:39 PM
ssk0771's Avatar
ZZ Boy
The Correct size of the tires should be
245-30-20 in the front with 26 inches in diameter
275-30-20 in the rear with 26.5 inches in diameter.
These numbers are closest to spec. If you go with 245-35 and 275-35 on
20's, you are going with Fat Setup.
Toyo's just started making 245-30-20's in T1-R
