Has anybody figured out a cause or fix
Old Jan 15, 2006 | 10:21 PM
bltzkrg's Avatar
Got a fix or cause for the center tread wear on the rear coupe 17s?
Old Jan 15, 2006 | 10:24 PM
baileyrx's Avatar
too much air. Drop the pressure a couple of pounds.
Old Jan 15, 2006 | 10:30 PM
bltzkrg's Avatar
Nah, I did that. I tried 35psi which is the manufacturer spec. and the wear occurred. I dropped it to 30 psi and the wear continued. How low are you talking. If I go lower the car handles like crap and it affects the gas mileage terribly.
Old Jan 15, 2006 | 11:30 PM
SilverII's Avatar
I found a fix..... I replaced the rim with some volks....
Old Jan 16, 2006 | 11:32 PM
EvolutionGSR's Avatar
Cheap fix is to have your local tire shop swap the right tire to the left side and vice versa. The way I drive I do mine about every 6-8 months. Thanks for reminding me I need to do it soon. The car seems to have a cambre from the factory. A decent tire shope usually does this for about $20-30 dollars a tire. Its a lot less than getting only half the wear on the tire than you should have. This also is good for those of you who have lowered the car but have not installed the camber fix kits.
Old Jan 17, 2006 | 08:10 AM
SilverII's Avatar
That wouldnt help center wear
5150DS
Sep 26, 2015 07:47 PM
Mhacker
Sep 12, 2015 07:35 PM
Chadwick Arnold
Sep 9, 2015 02:59 PM
JLee301
Sep 8, 2015 08:54 PM
