255/35-19 on Sedan f/r
i have 19x8.5 with 245/30-19 - with +43 offset. there is about a 4mm clearance between the wheel and the suspension, and the wheel is flush with the fender. i would not recomment going with 255 - it may rub. of course, if you go with lower offset, you will have to roll the fenders, and then it'll be ok.
Originally Posted by mark20001
Is anyone running 255/35/19 on a 8.5x19 wheel on the front of a sedan?
I'm running 18s but the spacing still applies.
Mine are 18x8.5" +42 with 255/40/18.
Spacing is great, not even close to rubbing on the fender.
