19x8.5 +35 offset
Old Jan 29, 2006 | 05:01 AM
stnwag0n's Avatar
19x8.5 +35 offset
with an s-tech or 350z h-tech drop, would 19x8.5 +35 offset fit ok on a sedan? will there be rubbing issues? I really dont want the wheels to stick out, but i dont think the wheels im looking at are offered in a +38 offset.
Old Jan 29, 2006 | 09:37 AM
Chico's Avatar
They will fit just fine.
Old Jan 29, 2006 | 12:58 PM
shodog's Avatar
You should be fine. In the front of mine I run a 19X8.5 with 35mm offset
Old Jan 29, 2006 | 05:20 PM
stnwag0n's Avatar
Is you car lowered?
Old Jan 29, 2006 | 10:50 PM
lelg35's Avatar
Do you have any shots of the rear wheels? It would be good to see how flush it sits under the fender.
Old Jan 29, 2006 | 11:02 PM
codeflux's Avatar
if you are lowered, you may have to roll your fenders. +43 would be a better offset.
Old Jan 30, 2006 | 01:54 PM
stnwag0n's Avatar
wouldnt +43 be a little too tucked in with an 8.5 wide wheel?
Old Feb 2, 2006 | 03:02 AM
shodog's Avatar
I have a staggered wheel set up so my rear wheels are 19X9.5 with a 35mm offset. I had to roll the fender to prevent rubbing on one side.
Old Feb 4, 2006 | 07:05 AM
skeleton_cru's Avatar
Sedan
For the sedan +38mm is optimum, but there are people that are running +35mm. When you lower your car you create negative camber which will help with any rubbing issues.
Old Feb 4, 2006 | 09:40 AM
Brent's Avatar
Rims
I have 20x8.5 35 mm all around Fronts fit fine and I have a 5mm spacer to clear brakes. On back I had to roll the fender because car is very low [top out side of tire is even with fender lip] and alinement is at factory spec.
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
TurTLe*
Sep 29, 2015 01:43 PM
ChickenTendrs
Sep 16, 2015 01:10 PM
