anyone running 285/35 bf goodrich kdw2
Old Feb 11, 2006 | 03:51 PM
teabag's Avatar
i was thinking of this set up but chris at f1 said that bf goodrich kdw2 are wider than other tires. wondering if i should go with 275 or stick with 285
Old Feb 11, 2006 | 05:28 PM
GThIrtYFiZle's Avatar
I was contemplating for a while on wwhat to do regarding those two tire sizes also, since I had already ordered my iForged rims. After a while of doing research calling places to find out if it would rub and talkin to other people I put in my order and I went with the 285/30/20, everybody told me I shouldnt have a problem with rubbing at all, as far as tire sizes go, that setup stays as close to stock as possible which is really good....
Old Feb 11, 2006 | 05:31 PM
vat_U_tink's Avatar
Im running 285/35/20. Without no rub . Youll have no problem at all.
Hope it helps.
Old Feb 12, 2006 | 04:04 PM
rdurkin05g35's Avatar
i was curious about this as well b/c i really want the kdws but they do not make a 275/30 only a 275/35 and i was wondering if the 285/30 would cause a problem???
Old Feb 12, 2006 | 06:33 PM
I have not yet received my rims but I did receive my tires. First of all in that size they look completely sick and second of all I have spoken to plenty of people who know a lot about this and everybody told I should go with this setup and that I wouldnt have any problems
Old Feb 16, 2006 | 07:51 PM
I just shipped back my BFG KDW 2's because after receving the tires I was told that they are too tall and wide so I most likely will have rubbing and definitely dont want to do any rolling. So I sent them back(they are HUGE) and bought the Toyo Proxy T1R's in the 245/275. These sizes I was assured wont rub and look great also.
Old Feb 17, 2006 | 12:23 AM
Triple8Sol's Avatar
People are running 275/35/19 no problem, so 285/30/19 should be just fine. Or are you going 20's? If so, then I'm not sure since I've never done research in to 20" tires...
Old Feb 17, 2006 | 05:30 PM
I am running 20", and some peoplemight approve it but speak to someone who know just a bit and they will guarantee you will have problems with those tires and that size, its just too wide and tall, rolling fenders might not even do it.
Old Feb 17, 2006 | 08:45 PM
KrazyKorean's Avatar
I had 285/35 in the rear with 19x10.5 +22 offset on le37t's. And when i lower it it rubbed so I grinded have of the fender away and have -3 camber inthe rear. And no more rub. Looks sickwhen wheels go right to the fender.
Old Feb 18, 2006 | 03:28 AM
teabag's Avatar
but isn't oem camber -1. i want to put 285/35/19 and 245/35/19. i am willing to roll my fenders or should i say shave them.(f1motoring) do you think it will rub dropped on H@R springs. with oem camber?
Old Feb 19, 2006 | 12:26 AM
blazinasian's Avatar
KrazyKorean- before you lowered, did the 285's work okay without fenderwork?
Take care.
Old Feb 19, 2006 | 12:29 AM
I dont know, cuz I installed my wheels and coils at the same time. I am assuming yes but then you have that ugly wheel gap. My car is low no gap at all.
Thebaws11
Jul 2, 2021 11:36 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
