Tein Suspension Choices
Re: Tein Suspension Choices
Thats the idea with the flex system and the EDFC.
<hr></blockquote>
Yes, but I hear conflicting reports on whether the softest setting is softer or harsher than the sport suspension, and I'm quite sure it's not as soft as the stock suspension.
<hr></blockquote>
OK here is what I got back from tein:
No the dampers cannot be set to a stock or softer setting, coilovers are
designed for added performance and handling. To add performance valving and
spring rates must be increased, if the damper had the range of stock to full
performance, that would be impossible as the spring does not have a range
that large. You can purchase different spring rates and we can re-valve the
dampers to accommodate your needs if need be.
Staff @ TEIN USA INC.
9798 Firestone Blvd.
Downey, CA 90241
Phone: (562)861-9161
Fax: (562)861-9171
www.tein.com
Downey, CA 90241
Fax: (562)861-9171
www.tein.com
Any Tein coilover system that has 16 way adjustable dampeners has a effective adjustment working range of + or- 2kg or 118lbs. And nessectating the need for revalving for me. Which or course kills my idea of going for CS coilovers with spring rates halfway between them and the flex system. Choosing different spirngs cost's $50 per spring and since they consider the rear springs as a special application, they cost more per spring @$75 to $100 per spring, again, if you choose to go with different spring rates for that application.
Frankly I'm leaning more towards Jics now.
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Poster: wil
Subject: Re: Tein Suspension Choices
Just to clear things about price.........type CS is cheaper than the Flex line and is not as aggressive as the Flex.
__________________________________________________ _
I already mentioned that the CS system isn't as aggresive as the flex system. From one of my post's above.
"The CS Tein's use spring rates almost identical to stock, but they have 16 way adjustablity. That moves us to the Flex system. In addition to being able to use the EDFC system on the Flex coilovers, they also use much stiffer springs than the CS coilovers. This will mean that the valving they use will also be stiffer than the CS valving."
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Umm.. Every place i've checked on price, the CS system is more than the Flex system by a few hundred clams. I'm leaning towards the basic system, instead of just the eibachs. A matched spring and shock seems like the way to go, rather than just the springs and killing my stock shocks.
Can anyone here get a good deal on the basic system?
narkotic (Newbie)
09/08/03 10:02 AM
The Eibachs springs for all the various FM platformed cars (the Z and the G's) don't use spring rates that are really very different than the stock spring rates. At best you will have one application that is 10% stiffer in the front or 8% stiffer in the rear on another. All the other rates are the same as stock or SOFTER. And remember I'm talking about the final spring rates. Eibachs are progressive where that have a softer than stock initial spring rate, so a certain percentage of your suspension travel occurs on rates that are softer than stock. Once the softer coils bind together, then the final spring rate takes over. MEANING, you not running truely stiffer springs that eat stock shocks.
But you will still have a performance advantage in NOT using progressive springs and sticking with the linear springs type of springs that Nissan gave the car from the factory. Coilovers use linear springs. The more you are likely to want to push you car handling wise, the more it make sense to go with coilovers.
Since the Tein basics don't have dampeners that can be adjusted, you'll have to trust that they come out of the box with a ride and drive value that suite's you. Based on how much people tend to praise Tein in general all over the net, I'd think you'd be pretty safe. Now, being that I don't like such risk's, I'd pony up the money for the CS system, even though it's springs aren't really any stiffer than stock and the Basic's spring rates are definately stiffer than stock.
Where did you see the CS systems for sale? I wonder if their so new that the site's you visited have posted MSRP because they don't even know their cost yet and are playing it safe, just my 2 cents.
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
09/08/03 10:02 AM
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Thanks Gsedan for the news on the Teins, I'm aware of that the shocks aren't adjustable, which is kind of hindering my decision. I'd really like to ride in a car that has all these coilovers to test but I know that just wont happen
, to answer your question regarding price, there are a few websites out there that sell the Tein systems, might want to do a Google search, but off the top of my head check this link:
http://www.tein.com/infiniti.html
The last 3 for the coupe there is the type:
Flex: $1860
CS: $1760
Basic: $890
My apologies for stating the CS system will cost more, must be my dyslexia popping in
I've e-mailed one company here in so. cali that seems to sell Tein parts. Quoted me $850 for the basics shipped to my door. I'd love to have adjustible dampers but for almost twice the cost I can't justify it. Maybe if I called tein they'd throw together some sort of custom package with adjustible shocks and basic springs? They seem like nice people.
-n
, to answer your question regarding price, there are a few websites out there that sell the Tein systems, might want to do a Google search, but off the top of my head check this link:http://www.tein.com/infiniti.html
Flex: $1860
CS: $1760
Basic: $890
-n
I plan on buying the TEIN suspension for my coupe. I setup this group buy with a friend whos cousin works for TEIN. Here's what I can get.
for the flex kit:
1 buyer-$1650 each
5 buyers-$1530 each
for the cs kit:
1 buyer-$1550 each
5 buyers-$1470 each
email me if intersted joe@joeyavino.com
Am I allowed to set this up and tell ppl on the form? If there is enough Mods/Admins interested, I will just rather stick with you guys.
The origional prices are as follows.
FLEX: 1860
CS: 1760
Thanks - Joey Avino
for the flex kit:
1 buyer-$1650 each
5 buyers-$1530 each
for the cs kit:
1 buyer-$1550 each
5 buyers-$1470 each
FLEX: 1860
CS: 1760
Thanks - Joey Avino
I'm leaning towards the Tein Flex myself as well. If only the Flex has independant bound and rebound settings!!! Esentially, what I would like is the Tein Type N1 with the spring rate of Flex, but unfortunately they don't even make them for the G35.
THX723
THX723
Keep in mind that the current flex system was changed from the earlier kits that many have installed and spoken on. They stiffened up the dampener valving and the spring stiffness. Basically the kit went from being a certain stiffness to a harder stiffness. Take a look.
Here's the difference percentage wise compaired to the stock suspension on a sedan with sport
Old Tein flex with 590lbs front and rear spring rates
65% stiffer in the front 45% stiffer in the rear.
New Tein flex with 671lbs front and rear spring rates
88% stiffer in the front 65% stiffer in the rear
Tein said they made the change because of complaints from enthusist's that the original flex system wasn't stiff enough. And that they brought out the CS system to catch the part of the market that didn't want the new flex systems increased stiffness.
Notice something else about the numbers, notice that on both applications that they increase front spring stiffness 20%, that will increase understeer. Which is something most enthusists are working to remove as it is. The way around it, just spend $130 more and order a pair of 590lbs front springs a new flex system is ordered, that will bring your spring rate back into balance. 66% stiffer in the front and 65% stiffer in the rear.
The other thing that someone could do is get the CS system, and order a pair of stiffer rear springs. Sticking with the CS's standard front rate will net you a 10% increase in stiffness over stock. Bumping the rears up a click to 448 will also bump the rear spring stiffness up 10%.
6mt sed
Crawford Pleneum
Injen CAI
Cusco sway bars
350Z springs&struts
Nismo header (soon)
True dual (soon)
6mt sed
Crawford Pleneum
Injen CAI
Cusco sway bars
350Z springs&struts
Nismo header (soon)
True dual (soon)
Gsedan35,
Thanks for the heads up on the changes made to the current line of Type Flex. When you said xx% over 'stock' ... I assume you're referring to the *non sports* spring rate, correct? Also, you're speaking as if you know the actual spring rate of the 'stockers'. Do you mind sharing that informations with us? I suppose I could just subtract 10% from the Flex and figure it, if I did not misinterpret your info
The Type-CS is probably too soft for me to care about and the lack of independant height vs. preload does not shine with me either.
Clint - '04 G35 Sedan - Sports Susp. - 6mt
THX723
THX723
"Here's the difference percentage wise compaired to the stock suspension on a sedan with sport"
I don't have the spring rates for the non sport yet. I will be getting a non sport suspension sent to me. When if does arrive I will find out the spring rates for the non sport and post that info. Have no idea of the time line however.
True about the CS lacking the independent height adjustment. And 10% isn't enough for me. But it might be what some people are looking for. A better choice than the HKS LS , IMO.
Running the current flex with its new stiffness rates should really be pondered very carfully and only run by those that want to say when their done, "Good god, this this is stiff". Choice very carefully and give it allot of thought. 65% stiffer isn't a slight change. Don't get caught up in it all, not thinking that you might actally have limits on what you can accept and tollerate.
Spring rates for the sedan with sport are
357lbs front and 407lbs rear
350Z and G35 coupe spring rates are 347lbs front and 419lbs rear.
BTW, Jics upcomming sedan FLT-A2 coilovers are using a poor choices in spring rates. 504lbs front and 392lbs rear. Notice how thats actually a tad softer in the rear. Can you say understeer factor. I warned then that them that they are a performance name plate and that their specs are anti performance. Their sticking to their guns, but point of fact is, people that know better won't place that setup on their shopping list, something I also warned them about.
6mt sed
Crawford Pleneum
Injen CAI
Cusco sway bars
350Z springs&struts
Nismo header (soon)
True dual (soon)
6mt sed
Crawford Pleneum
Injen CAI
Cusco sway bars
350Z springs&struts
Nismo header (soon)
True dual (soon)
