Scraping something on freeway
Old Aug 24, 2003 | 01:45 AM
gdupg35's Avatar
I realize I've posted regarding my rubbing issues, but this doesn't seem related. My sedan is lowered with Eibach's on 20" ADR Sterlings (I don't know the offset). When I hit big dips on the freeway, it sounds as if the tires are coming in contact with the plastic fenderwells.
I wonder if trimming the plastic would cure the problem.
It seems to me that this problem has nothing to do with the offset of the wheels, as I'm going in a straight line., and contacting tire to top of plastic fenderwell.
Has anyone else with 20"s, and lowered have this problem?
2003.5 6MT SEDAN
20x8.5 ADR STERLING
245/35 NITTOS
EIBACH PROKIT
ZEX WET NITROUS KIT (75 SHOT)
Old Aug 25, 2003 | 01:44 AM
BenmaN's Avatar
Re: Scraping something on freeway
Have you changed your oil lately? This may sound stupid, but the first time I had my oil changed, the shop didn't screw down the plastic underneath the engine at all the original holes. Everytime I hit 60.. the plastic would catch some air and scrape on the ground. You should check it out also. If the scraping sound is only at higher speeds, I think you should take a look under your car too. Hope this helps.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
R350k5
Oct 1, 2015 08:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
AesonVirus
17 Inch
Sep 20, 2015 02:05 PM
Felipe Gonzalez
Aug 16, 2015 10:02 AM
