Lost Rim lock key
Old Mar 16, 2006 | 08:38 PM
RBJ's Avatar
RBJ
Lost Rim lock key
Hello guys,
I need your help. I had a flat tire today so I called up Infiniti emergency road assistance. They came after like an hour or so and then the guy who came to change the tire, asked me about the key to unlock the rim (i had driver side rear tire flat). I didnt know about this key until he asked me. So then I started looking for the key in the trunk, glovebox and all the possible places and couldnt find it. So he pumped up some air into the tire and I drove to nearby PEPBOYS. I turned my car in and then came back after like half an hour. When I came back, PEPBOYS also told me the same thing that they couldnt find the key and they tried universal key that they had but it didnt work either. So now I am helpless. I kept my car at PEPBOYS because once I reach home and then if something happens It would be more difficult.
Does anybody know that can I get another key for that lock ? Or can the Infiniti Dealer help me in this ??
Please help me guys..
Old Mar 16, 2006 | 08:46 PM
Sidewy8's Avatar
Try the ghetto style.
Find a sock that just fits over the lug lock. A better socket would be one with 16-32 tooth. Wrap red shop towel around the lug, like you're putting on a condom. You may have to double or triple up, depending on how the socket fits. Bang the sock over the lug. With the shop towel, it should be a tight fit. slight damage to the lug (exterior scrapes), but no big deal. You'll have to replace all 4 if you can't find the key.
Once its on tight, use a socket wrench and unscrew like you would any lug. If it twists, more shop towel padding or a tighter socket.
This worked for me. Good luck.
Originally Posted by RBJ
Hello guys,
Old Mar 16, 2006 | 09:13 PM
escobar929's Avatar
Hello guys,
when you bought the car you should have gotten a serial # for the lock. most are mcgard. contact them, give them the serial # and they will send you a new one
Old Mar 17, 2006 | 01:38 AM
truplay8's Avatar
THE BATMOBILE
exactly......its your only option
Old Mar 18, 2006 | 07:07 PM
jgainnm's Avatar
Did you check under the spare? That's where my dealer put mine when I bought the car.
arora_g35
Apr 16, 2026 02:52 PM
pasjr1972
Sep 1, 2015 10:17 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
