Cant stand the brake dust ANYOMORE!!!!!!!!!!!!!!!!
Old Sep 22, 2003 | 05:48 PM
vgrani1g35's Avatar
Re: Cant stand the brake dust ANYOMORE!!!!!!!!!!!!!!!!
I HAVE THE BREMBOS AND GET THE SAME AMOUNT OF DUST ON THE FRONT AND THE BACK. BY THE WAY, YOU SHOULD NEVER CHANGE JUST THE FRONTS OR THE BACKS WHEN YOU ARE SWITCHING BRAKE COMPANIES, AND ESPECIALLY WHEN YOU ARE ALTOGETHER CHANGING TO A COMPLETELY DIFFERENT MATERIAL PAD. YOUR BRAKES WILL WEAR UNEVENLY. I NEED AXIS METAL MATRIX PADS FOR THE FRONT AND THE REAAAAAAAAR AS WELL! WHO THE HELL JUST WANTS TWO CLEAN WHEELS. THAT WOULD MAKE ME MORE CRAZY.......
Old Sep 22, 2003 | 09:46 PM
SalTNutz's Avatar
The OEM pads on the auto don't create dust problems in the rear. And what the heck difference does it make when you replace the front and back seperately? You said it will cause uneven wear???? I hate to tell you, but your front brakes will wear out WAY FASTER than the rears anyway. If you replace you rears everytime you replace your fronts, you are throwing money down the drain. And with those expensive as hell Brembo pads, I bet you'll be stoping that real quick.
Old Sep 23, 2003 | 08:50 AM
KongzGx's Avatar
i can't find the axxis pads anywhere... and nobody seems to have the rear pads yet.
'03 G35 Sedan: ivory/aero body/sport/sunroof
Warning: Objects in mirror are FASTER than they appear
Old Sep 24, 2003 | 12:53 PM
ryoken's Avatar
And on the flip side, if you don't want to mess with the brake bias, you need the same type of pads front and rear.
KruZZe
Feb 27, 2023 05:04 PM
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
