G35 OEM 19's with Project kics spacer installed!
on
Originally Posted by kenchan
i'll have to see it directly from behind, but 20mm on the rear might push
out the wheels outwards too much vs the width of the wheel and tires
making it look weird (like a crab) from behind.
what tire size are you running?
looks ok from the side and front.![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
Tires are stock:
225/40R19
245/40R19
on
on
Originally Posted by accordfreak
does it have any affect on the wheel bearings? I heard it does but then I hear it doesn't..
I see that the car looks lowered, but can all of you guys really see that the wheels are pushed out? From the pictures I can't really tell. Do you have any "before" pictures to compare? Take a picture from behind one of the rear corners, where we can see how rear and front wheels sit against the body, I think this will show more.
Originally Posted by CPALIU
i would think with spacers that thick, you would also need to replace the studs.
I know that the H&R Trac+ Spacer's come with extended bolts as well.
To the thread starter:
I was also thinking of getting spacer's for my stock 18's, 25mm Rear and 15mm Front to make them more flush.
1) Do you have any rubbing issues while taking corners hard?
2) Total Cost? H&R's are ($270 on ebay) for 15mm/25mm shipped.
3) 25mm rear too much?
Thanks
Btw, I am also considering widening my stock wheels to 10" so I can fit 285's and it also won't look wierd from the rear.
#30
Very nice - I think I'll order a set. The car should've come like this stock. Its been a pet peeve of mine that the wheels are not flush with the fender.
Now that you have them would you change anything? The rears looks really flush but the fronts look like they could come out a bit more.
Any chance you get a few shots w/o the shadow and a shot directly from behind the car, bumper level.
Again, nice mode.
Again, nice mode.
