average cost for 19" rims and tires?
Old Mar 27, 2006 | 11:35 AM
04Gwhiz's Avatar
any combo of brand...9.5 front and 10.5 rear?
Old Mar 27, 2006 | 11:38 AM
Texasscout's Avatar
Don't think you can put an "average" to this. A range maybe. $1300 to $6000 depending on brands.
Old Mar 27, 2006 | 11:41 AM
BlackDiamond80's Avatar
+1.
Old Mar 27, 2006 | 11:42 AM
04Gwhiz's Avatar
sorry your probably right..just want to see what people on this board have spent on their 19" setups..
also what is the difference between a 2 piece and a 3 piece wheel?
also can I assume all wheels are forged or does it have to be stated...like do 3 pieces only come forged...is this better for me?i live in NY...does it matter..is the rim any stronger if its forged?
Old Mar 27, 2006 | 01:07 PM
HotRodW's Avatar
3-piece wheels are typically lighter weight than 2-piece wheels, but as a rule they're also more expensive. There are exceptions of course.
Not all 2-piece wheels are forged, nor do they need to be. PIAA manufacturers very nice cast 2-piece wheels.
I found most quality 19" packages range from $3,000 - $4,000, with some going substantially higher.
Don't buy anything until you know the weight, regardless of the wheel construction.
Old Mar 27, 2006 | 01:11 PM
eledin's Avatar
What kind of weight range should we want?
Old Mar 27, 2006 | 01:12 PM
WhosUrBuddiee's Avatar
I have 3 piece rims that are almost 35 pounds each.
Old Mar 27, 2006 | 01:27 PM
Texasscout's Avatar
35 pound?, I hope that's with tires I have seen them as light as 18 pounds, Here is a tech article from "Turbo" magazine that helps you to understand weight and it's relationship to HP. Also, if you have access to the current issue of "SportZ" magazine, they have a huge article on wheels this month.
Old Mar 27, 2006 | 03:54 PM
HotRodW's Avatar
Try to keep the wheels under 30 lbs. each. Many of the more common 19" wheels (Volks, PIAAs 5Zigens, etc.) typically range from about 24 - 29 lbs. Watch out for the knockoffs - they may look the same but they can weigh a lot more. BBS makes some lighter weight stuff, like the RS-GT (awesome wheel), but you'll definitely pay more for them. If you're seriously concerned about the weight, go with 18's. And don't forget to consider the tires - they vary in weight, also.
Old Mar 27, 2006 | 04:45 PM
04Gwhiz's Avatar
now are 20's or 19's cheaper in the long run?
Old Mar 27, 2006 | 04:48 PM
KrazyEd's Avatar
I mean this is a really tough question. I would put the median for the wheels/tires at around $3,500. Some people pay close to $6,000 and others can get some deals and get rims as low as $1,500.
It really depends on if you want 18s, 19s, or 20s, what color you want?, etc.
Old Mar 27, 2006 | 06:28 PM
HotRodW's Avatar
19's will be way less expensive up front and in the long run. There really is only one advantage to going with 20's over 19's, and that's appearance. 19's cost less, the tires are less expensive, they weigh less, and they're less prone to pothole damage.
Old Mar 27, 2006 | 10:49 PM
Actually that is without tires.
Old Mar 29, 2006 | 12:51 AM
No1Better's Avatar
Mine can be had at a reasonable price if you are So. Cali!
vitamin.v
Nov 7, 2019 06:10 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Gip
Aug 24, 2015 05:31 PM
JaeXL
Aug 4, 2015 07:43 AM
