Goodyear Eagle F1 GS-D3
Old Apr 2, 2006 | 08:01 PM
y.dan's Avatar
I am looking for new tires,
I have stock 19" with Project kics spacers (15mm, 20mm), stock '05 sports suspension
i love these tires but there r no exact stock fitments for both front and rear tires so i was wondering if these sizes will fit the stock 19"
FRONT:
225/35 YR19
88Y XL
7.5-9" (rim width range)
8" (meas. rim width)
235/35 YR19
91Y XL
8-9.5" (rim width range)
8.5" (meas. rim width)
REAR:
245/35 YR19
93Y XL
245/40 YR19
98Y XL
255/35 YR19
96Y XL
8.5-10" (rim width range)
9" (meas. rim width)
any recommendations?
ALSO, for those who read Car and Driver's article on "The Best Performance Tires", UTQG tread-wear grade, higher is better right?
because this tire had the higher number and our potenza had the lowest number.
Old Apr 2, 2006 | 08:37 PM
blackonblackG's Avatar
I have had these tires on my car for 15k.
1 word - HEAVY.
I now have the very light contisportcontact2s and I like them very much.
Old Apr 2, 2006 | 09:38 PM
AboostedG's Avatar
I too am interested in the Different Sizes as I want to upgrade my Stock Tires on my 05 Coupe 6MT.
I've been looking towards some BFGoodrich KDW-2's.
Any other opinions??
Old Apr 3, 2006 | 03:55 AM
ISMSOLUTIONS's Avatar
I have 245/35/19 on front and 275/35/19 on rear - stock 19's on my 05 coupe...Michelin SP2's...quiet - lots of traction wet and dry - love them bunches!
Rick
Old Apr 3, 2006 | 04:06 AM
y.dan's Avatar
ISMSOLUTIONS:
r u saying those wide PS2 tires u got fit the stock 19" rims?
any uneven wear or any problems?
also, using 35 series tires will make the speedometer a bit off correct? anyway to correct that?
thanks for all the feedback,
Rick
Old Apr 3, 2006 | 04:10 AM
y.dan's Avatar
blackonblackG:
wut sizes were those eagle F1 tires? on wut size of rims?
contisportcontact2 is a lighter tire even compare to the potenza..
1 word - HEAVY.
Old Apr 3, 2006 | 04:11 AM
Originally Posted by y.dan
ISMSOLUTIONS:
They fit perfectly - no speedo hit, well about 2 MPH, wear is perfect - and the added 1 1/4" of tread works very well too!
Lou - if your out there - i know you'll chime in too. There is a difference of opinion out there for safety and what not - for 'tire bulge' etc - this topic has been talked about a bit on the board - search under my handle for '275' and you'll see pics and the rest...
Rick
Old Apr 3, 2006 | 05:28 AM
AboostedG's Avatar
Rick
PICS??
Old Apr 3, 2006 | 08:44 AM
Pratik's Avatar
Moderator
For what its worth I have these tires and think they're the best tires I've ever driven on. I have them on 19" Nismos so weight isnt really an issue. Cornering is better and road noise is reduced.
Old Apr 3, 2006 | 09:10 AM
Texasscout's Avatar
Those numbers are only relative WITHING the same BRAND of tire. You can't use them to compare two DIFFERENT brands of tires.
Old Apr 3, 2006 | 10:08 AM
Originally Posted by AFitchTLS
PICS??
See my 2nd post = search for them...
Old Apr 3, 2006 | 11:55 AM
jgainnm's Avatar
Old Apr 3, 2006 | 01:45 PM
blackonblackG:
I had them on my sedan 245/45/18 all around (same as stock rear 18" coupe). they were 29lbs each. My current contis in 245/40 18 are 23lbs each. Mounted on light weight 18 by 8 " rims.
Old Apr 4, 2006 | 02:30 PM
y.dan's Avatar
can other people confirm this?
because our potenza is only rated 140
but the those eagle f1 is 280..
Old Apr 4, 2006 | 02:33 PM
papagz's Avatar
that is without a doubt correct. they are only used to compare within the certain brand
