Tein Flex and Camber
The tein flex coilovers with EFCD was oneof the first things I was thinking about doing to my G but does it affect the camber. Will the camber move when you raise and lower the car. I dont know much about coilovers so could someone shed some light on what would happen if I install some Tein Flex's? Also does rims affect it, say if I was going to put on some 20' rims to?
Re: Tein Flex and Camber
The EFCD allows you to adjust the dampning from the inside of your car even while driving. This won't really affect your alignment, but will effect your ride confort and handling.
If you lower your car alot, you will need a camber kit, so that your car will have perfect alignment or to some people, with a little negative camber instead of a lot for better handling.
The camber will be affected when you raise or lower your car, so don't get an alignment until you have set your car to desired height.
Rims won't really affect your camber, but it may affect how much you may want to lower it. Consider the width and height, so that you will avoid rubbing when you get everything.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
