Upgraded Wheels - TPS Sensors?
Originally Posted by DJM AutoWorks
you shouldnt have to do this you can just replace the rubber valve stem with the tire pressure sensor/valve stem setup
on
It depends on the particular wheel, the sensors sometimes don't mount at the right angle, and will get damaged when the tire is mounted
