20's on COUPE!
Old Sep 18, 2003 | 02:26 PM
motorious23's Avatar
20's on COUPE!
Has anyone put 20's on there g.....so that the tires can be rotated. What size tire can you put on so that it still looks good? Anyone........?
Old Sep 18, 2003 | 07:08 PM
Growler's Avatar
Re: 20's on COUPE!
I think g356mt (forum member) is running 20" Volk wheels.
Old Sep 18, 2003 | 09:10 PM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
Re: 20's on COUPE!
Wreck has 20" 5 Zigen, blk6pd has 20" Maido, Look around a Few others have 20" ALT's and other wheels.......
NismoCPV-35
Old Sep 18, 2003 | 09:22 PM
a2ncharm23's Avatar
Re: 20's on COUPE!
I have 255/35/20's all around so that i could rotate wheels. Tire sidewall isn't too small or too large
2003 CB G35 6MT
3M masking
black chrome emblems
15% tint
Sparco pedals
painted engine cover
20" ADR sterling
PIAA l.e.d
K&N filter
CF dash
grounding kit
350Z intake
RS*R springs
Old Sep 19, 2003 | 07:26 PM
narkotic's Avatar
Re: 20's on COUPE!
Volk does not make a 20" Wheel. His are 19's.
Old Sep 19, 2003 | 09:46 PM
lowrider's Avatar
Re: 20's on COUPE!
You've thrown off the stagger which was built into our cars, for proper handling of all the electronics - VDC, slip control, ABS, proper distribution of weight under braking and etc. I'm not sure what else. I do always drive with VDC off, but I do think that maintaning the stagger is important. It's about an inch different between the front and the rear. Stock ODs are:
Front - 25.8"
Rear - 26.8"
Yours - 27" all around.
Lou
Old Sep 19, 2003 | 09:57 PM
englishguy's Avatar
Re: 20's on COUPE!
i went with 245 35 20 all around so i could rotate. personally i think the car handles better with 20's but that could just be me.
Old Sep 20, 2003 | 03:42 AM
Rob_G35's Avatar
In Search of Magic
Re: 20's on COUPE!
gtorres44
Did you know that Michelin tires are very expensive. I would go with some Yoko's or something like that. They are way cheaper.
Old Sep 20, 2003 | 08:57 AM
Nismoboy's Avatar
Re: 20's on COUPE!
gtorres44: the price difference isn't really that much when your talking 19's and 20's...check it out www.onlinetires.com **** some 19in tires are even more expensive
John H.
2003 Infiniti G35 Coupe 5AT-Ivory Pearl-Premium Pkg-Performance Pkg.
Old Sep 21, 2003 | 10:01 AM
kgresham's Avatar
Re: 20's on COUPE!
20" Chrome Miado - handle's very well, the look is awesome!!!!
Old Sep 21, 2003 | 10:20 AM
Nismoboy's Avatar
Re: 20's on COUPE!
to be honest with you the best tires for the money are probably the Falken GRB FK-451 you can find on www.onlinetires.com you can probably get all four tires for under $900 shipped, like 255/35/20 front and 285/30/20 rears...FYI if you put 20's up front its gonna be hard to match the exact diameter of the stock wheels/tires...you need a 245/30/20 to be exact but not many tires in that size out there...i think www.tirerack.com has like one tire in that size and i think its a lil more pricey
John H.
Old Sep 22, 2003 | 10:26 AM
R1cky's Avatar
Re: 20's on COUPE!
Can I ask what size and brand of tire r u sittint on? Thanx...
Old Sep 22, 2003 | 06:45 PM
kgresham's Avatar
Re: 20's on COUPE!
Bridgestone Potenza S-03 - 245-35-20 front; 285-30-20 rear.
They ride pretty good.
