z springs front/ coupe springs rear--ID reference
#31
Originally Posted by DangerMouse
Hi 68_GT,
I bet you have the same front springs as I do - revised (05+) G35 coupe sport springs with a spring rate of 314lbs-in. I do not have the non-sport springs to compare with, but believe they are the same length (and spring rate) as the regular coupe front springs.
Here's one reference post (OEM 19-inch wheels) -
https://g35driver.com/forums/brakes-suspension/98419-will-springs-really-ruin-your-ride.html
Dan
Dan
#32
I've just bought a used set of 350z suspension from an 05 model (springs and struts) with only 10,000kms. My questions is..should I just fit the springs on my stock struts or should I replace the whole 350z setup in my sedan..seeing as my stock struts have done more than 30,000ks. Any pros and cons in doing so? Mine is an 05 sedan.
#33
on
1. Your stock rear shocks will not hold up to the spring rates of the revised 350z springs.
2. No spring compressor needed to swap the stuff out making installation much easier.
3. It's a factory matched set. Not that it probably really matters...
I have an 05 sedan and I am about to do this also!
#37
#38
#43
#44
#45
https://g35driver.com/forums/2833639-post2.html
