Best next upgrades after Vortech installation on stock block?
Building a bottom end (pistons/rods) gets real expensive and real time consuming. That alone isn't going to make your car faster, it simply makes the motor stronger so you can safely add more power. If you're going to tear down the bottom end you need to do both pistons and rods together. You'll also need to get the block bored/honed for the new pistons, new main bearings, and new gaskets. While you're in there you really need to do new main studs, a new water pump, and new front/rear main seals.
If I were going to build a bottom end I'd look for a good machine shop, preferably with some considerable VQ experience. Then I'd buy a spare block and have them assemble it while you're car is still up and running. Once the block is ready it'll make the transition much easier and quicker, then you can recoup some of the cost by selling your stock bottom end after you swap the built motor in.
Cams are simply a power mod, they're not going to make your motor stronger, just make it produce more power. All they do is increase the airflow to the motor, much the same as if you installed a smaller pulley. If you just want a little more power the smaller pulley would be the best bang for the buck. If you're really going for some serious power the rods/pistons are the logical option, do the safety+strength stuff first, then look for more power.
Our tranny won't handle 400whp or something? What about auto...I have valvebody upgrade and maybe tranny cooler install soon that enough for SC?
