2005 G35 dead battery
battery is about 1 year old. Duramax gold. connections are clean.
If it sets for 3 days chances are it won't start. I've actually backed it out of the garage, opened all the windows and doors and spent a while cleaning it/changing the oil (hour?) and it would be low enough to need a jump.
If something is drawing it down that fast, you would see a far bigger drain on the battery than 0.1A. Even an interior light left overnight shouldn't be an issue for a healty battery to handing in the AM.
0.1A is not that much. I don't think you have a parasitic drain issue here. Your problem lies elsewhere in the charging system. Bad alternator, poor/corroded connection, or a weak battery. Does that battery have a removable top plate where you can see the battery cells? Are they submerged or are the cells dry?
After the BCM goes to sleep you should have no more than 50 milliamps. That is all that is considered allowable due to clock and alarm. If I remember correctly that fuse is actually 3 fuses put together and I think the ignition is one of those fuses. What I have seen the most in the past is something tied into the ignition switch such as mobile guardian,etc. and that has been the draw on alot of vehicles. I have also seen cars that have been financed and the car lot installed a GPS tracking device until car has been paid off. Those will cause issues also if they are tied into the wrong wire. Hope this helps brother.
Gary
That explains why you overthought the current drain issue.
I'm a mechanical engineer. I say there and did floor load calculations for a few days before I put a 125 gallon reef tank on the 2nd floor of my place. I overthink stuff way too often
