Do the rear brakes last longer than the front?
Old 01-28-2007, 12:42 AM
GuyLegend's Avatar
That's what one of the mechanics said at a local shop here. In fact, he said that RWD cars usually have a 3:1 ratio of changing the front pads/rotors compared to the rears.
My brakes have been sqeaking and howling a whole lot. I had the fronts replaced as the rotors were clearly worn, but didn't do the rears and the squeaking and howling persists like crazy. I know that the G's are known to have noisy brakes, but the sqeaks and howls every time I come to a stop are ridiculous. I'm thinking of taking a look at the rear brakes....
Old 01-28-2007, 12:48 AM
filanj's Avatar
my back pads went wayy before my fronts... sounds like ur mechanic was just wiseballing you
Old 01-28-2007, 12:51 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
The rear will normally last longer on all cars since the front brakes do 70-80% of the braking.
-GP-
Old 01-28-2007, 01:00 AM
wilksoner's Avatar
rear should last longer the majority of ur brakin power is from the front
Old 01-28-2007, 01:04 AM
avengence's Avatar
Yep your back pads should wear slower than your fronts
Old 01-28-2007, 01:20 AM
GTR_Boy's Avatar
For regular driving, your front pads will wear faster than your rear pads, as most of your braking force is at the front. If you drive aggressively, your rear pads will wear faster also. Why is this? When launching or cornering hard, your rear wheels may slip and lose traction mometarily. This is when VDC and TCS kicks in and applies the brakes to the rear wheels to stop the slippage. So when you make your "Slip Light" on the dash go off, remember this.
I noticed I had to change both my front and rear pads at the same time at 49,000 km.
Old 01-28-2007, 01:41 AM
cloud's Avatar
for some reason I have 8mm left in the fronts and 3mm left in the rear... hmm
Old 01-28-2007, 03:01 AM
Maximus's Avatar
the rears are smaller to begin with
Old 01-28-2007, 08:24 AM
dave's Avatar
I've had the front pads changed 3 times, and the rear pads changed once.
On every car & motorcycle I've owned, the front brakes have always worn much faster than the rears.
Old 01-28-2007, 08:59 AM
Nismo G's Avatar
yes, rear outlast the fronts... i think its 70% of stopping power comes from the front.
-sean
Old 01-28-2007, 10:41 AM
Kidcane's Avatar
Just think about it. It makes sense that the front would do the majority of the stopping so they would wear faster.
Old 01-28-2007, 11:05 AM
Rphillips6487's Avatar
yes, more tension is put on your front brakes than your rears in most cases
Old 01-28-2007, 11:17 AM
Nismo G's Avatar
more weight in the front as well...thats the main reason the front brakes go fast.
-sean
Old 01-28-2007, 11:35 AM
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
The truth is............
Here's an example.......I had a '92 300ZXTT and replaced the factory brakes
at 118K miles. The front pads were 85% worn and the backs were 30% plus
I never had issues with dust or squeeks. Yes, it was a stick and I spent most
of my driving on the freeway but those were some great brakes! On a FWD
vehicle the front brakes alway go first unless of course there are issues with
the rears.
Old 01-28-2007, 11:49 AM
Dubfound's Avatar
I had a 1990 Acura Integra and I had to replace the rear brakes every year?...... ******* sucked!!! Good car though
Quick Reply: Do the rear brakes last longer than the front?
