Fixing Various Issues on My Coupe - Cost?
I recently bought a 05 g35 for a good price but the bottom door on both side has these show in these pics. https://i.imgur.com/ur6JA6z.jpg https://i.imgur.com/IBYVx1O.jpg on both side bottom door. It really ticking me off. Hope someone know how to fix this or a least make it less noticeable.
Cut, sand, touch-up (paint). Basically do what you need to camouflage. Its a pointless piece that has to use, and if you hide it well no one will ever notice. Not even you.
Mine were peeling and I just sliced them with a razorblade in the same spot on both sides. Looks like it was made that way.
05 G35 Passenger Mirror
My 05 G35 Coupe Passenger mirror wont go down when i press the button on my door. It was working 40 min ago when i got home i try to row down the window for some air. Do i really need to replace the motor just bought the car and already has problem. Any tips and help will be greatly appreciated.
You mean Window.... not mirror, i take it. Window motor failures on these cars are pretty much almost guaranteed if you own your car for a good length of time.
Remove the door panel, take the motor out and clean it and reinstall. It will probably work again for a few more years if you do that. I did it to my car on my divers side and it's been working great for about a year and a half now... knock on wood.
How much will this cost me to fix these damage?
I contact a fix dent place i found through yelp they told me they can fix it. Currently waiting for another place to reply. I dont wanna it to bring it to the shop i know they gonna hit me with 800-1k. Any help recommendation? I live in California Bay Area. Any help will be greatly appreciate.
In order to fix it properly and have it look right, the whole quarter panel will need to be painted. A body shop will have to fix the dents, prime and base coat the affected area. Then they will have to clear coat the whole panel to blend. From the sounds of it you wanted to just get the dent out? What about the paint? It will rust and create more problems.
No one here can really tell you how much it will cost. We can throw out numbers back and fourth, but you need to take your car to different body shops and get quotes. Look on Yelp for some good reviewed shops.
If you could estimate the price how much would u think this will cost me ?
with the whole rear quarter panel replaced, repainted you should be looking at 1500-2000. Without quarter panel replace, where it just needs fixing and repainted, then 1000-1500. I had a damage like that a few months ago, only it was a little more extensive, like i had to replace the door, but the panel was fixable, so i paid around 2K. I hope that helps in your searching for a good rate.
