Starting Problems
Starting Problems
Any help is appreciated.
So I'm having problems starting my car. I can turn on the ignition to acc and on. Everything looks fine and I can hear the fuel pump. As soon as I start to crank the engine nothing happens. No cranking or clicking, all the lights on the dashboard are turn off. All power is gone from the car. None of the interior lights work, even the power locks.
My battery was replaced about 4 months ago.
First thing I'm going to check when I get home is the fuses and take the battery to autozone to have looked at.
electrical problems are always difficult to diagnose especially without knowing what you have checked.
Could be anything from fuses, relays, to ignition switch. generally speaking here,
the fuel pump primes... check fuses.
Maybe someone has had an issue like yours.
If there is no power going to the starter the engine wont crank obviously
so did this happen out of nowhere? did it start and no problems...
give us some more info,
I got my G running again. Somehow there was a loose connection with both battery terminals. Everything looked good but went to autozone anyways to get it checked out. Starter and alternator were fine but my battery came up as bad only after 4 months of use. Got it replaced under warranty.
If you have a battery that is slightly smaller than stock dimensions, it may have slipped out from the initial tightening position due to those L-Brackets not lining up and the vibration and constant battery movement may have loosened the cables and also possibly even damaged the battery internals.
