Loud pulsating noise from rear tires
I just recently replaced all my pads and rotors. Just afew days ago I started to notice that there is a loud pulsating vibrating sound coming from one of the rear tires. It usually starts off some what quiet and it progressively gets louder as I go faster. 70-80 on the highway. I think it's coming from the rear right tire but I am not certain. I kind of think that it might be the rotor rubbing against the pads but the weird thing is that after about 10-15 minutes of driving at highway speeds the pulsating vibrating noise slowly goes away. I installed the slotted stoptech rotors if that helps. They look really nice and stop well. Anyways... It's getting very annoying and I'm at a lose as to what could be wrong. I really need help! Any suggestions?
Could be a rotor that's out of round. Check your tire pressure too. Sometimes overly inflated tires will do this. Could also be flat spots in the tires from sitting overnight that eventually goes away as the tires warm up and the rubber becomes more malleable.
My crappy Falken FK452's do that a ton but my Nitto Motivo's do not.
You could have also knocked a wheel weight off in the process of working on the tires but I would think it would continue to do this all the time if that was the case rather than go away after a while.
I did not even see the "goes away" part. Bearing noise will not go away unless changed out. I take my answer back.
Is it a scrape? A metallic sound? Rubbing sound?
Could be:
Dust shield rubbing on rotor
Slotted rotors do sometimes make a "wiping" noise as the pads pass over the slots
Tire issue (can you temp rotate the tire to other side to confirm noise stays)
Bad bearing (usually doesn't go away, but I've had bearings louder on rainy days, than sunny days)
Gerbil in wheel
Could be:
Gerbil in wheel
Could be:
Gerbil in wheel
Could be:
Gerbil in wheel
Could be:
Gerbil in wheel
Could be:
Gerbil in wheel
I figured it out and it was very dumb. The whole problem was that when I last took my tires off to replace everything, after driving 200 miles or so the lug nuts must have become unevenly loosened. That cause more pressure to be put on one side of the rotor making it tilt. That then cause one part of the rotor to rub against the pads making the pulsating sound I was hearing. This friction then caused brand new brake pads to be completely worn out in a matter of 50 miles or so. I guess the moral of the story is to always check your lug nuts. Also if it does matter, the longer slide pin with the bushing on it goes in the top, not the bottom. Don't mix them up. Now she drives like a champ again. Hope this helps anyone else who might encounter this problem!
Glad you got it figured out. Sometimes doing your own maintenance can bite you in the a$$ but at least you probably learned from it and will be aware of both things next time. Be careful torquing down those lug nuts too.. doing so with improper technique can lead to problems and damaged rotors and lugs.
rezendvous420
05-31-2020 01:26 PM
yellowshirt
Wheels & Tires CDN
04-08-2018 06:09 PM
