Help with test pipe/oxygen sensor.
Old 05-27-2015, 04:10 PM
itztwinki3's Avatar
So I have a set of test pipes that just came in a few days and I am trying to install em. I am trying to find out which o2 sensors am I suppose to put into them?
upstream? downstream? part number for these o2 sensor will be a big help. the sensors that were on my oem cats are gone. So I am trying to find out which sensors I need to put in. are they before cats or after cats? downstream or upstream?
thanks in advance.
Old 05-27-2015, 04:34 PM
Texasscout's Avatar
Received 2,116 Likes on 1,768 Posts
Don't know this for sure, but I would think they would be the same front and back. So a OEM aftermarket should work.
Old 05-29-2015, 10:21 PM
herrschaft's Avatar
Upstream. The downstream go in the exhaust. Are you saying the the sensors are missing completely? There should be 4 total.
Old 05-31-2015, 02:47 AM
iluminati10's Avatar
thanks in advance.
if u put aftermarket ones u need spacers for the sensors for dont get the check engine light
Old 05-31-2015, 12:40 PM
Texasscout's Avatar
Keeps them out of the direct line of fire of the exhaust flow. They will crud up and give a false reading if spacers are not used.
KruZZe
02-27-2023 05:04 PM
andrewvk
Engine - Complete Motors
32
04-07-2016 01:39 PM
Red G Coupe
Tuner & Dyno
01-14-2016 01:13 AM
prinny
11-22-2015 11:07 PM
Visionnn
10-03-2015 05:16 AM
Quick Reply: Help with test pipe/oxygen sensor.
