MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction > Intake & Exhaust
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
  #46
Old 08-24-2009, 04:15 PM
Andrei's Avatar
I found this 350evo sway bar that is better and cheaper than OEM and it looks like it clears a dual exhaust. Should of done my homework more before I bought the OEM 2nd gen one.
http://www.350evo.com/catalog/produc...roducts_id/148
They also have a short throw shifter that use the stock shift knob.
  #47
Old 08-30-2009, 10:22 AM
Andrei's Avatar
I found out that the rear sway bar from the 2nd gens fits 1st gens and the 2nd gen sway bar will clear a dual exhaust. The front 2nd gen sway bar DOES NOT fit 1st gens. And the 1st gen rear sway bar doesn't fit 2nd gens. I should be good to go next weekend with the 350evo sway bar above.
Even though there is room with the stock 1st gen sway bar for a 3" pipe I like the 2nd gen just because it's symmetrical and it's a lot less work for me.
  #48
Old 09-02-2009, 04:24 PM
Andrei's Avatar
The 350evo sway bar I ordered does not have bushings and the bushing wont be shipped until the 10th so I canceled the order. I will use the stock 2nd gen sway bar.
  #49
Old 09-19-2009, 05:21 PM
Andrei's Avatar
Update on this as of last weekend. The test pipes are installed and the car averages better MPG now and there is a noticeable difference in throttle response and power in the upper RPM ranges but I wont see the full benefit of this until I complete it. The test pipes are at least 50% lighter compared to the cats. I am also hoping that I can bring the transmission down in the future without removing part of the exhaust once I complete this.
Install time for the test pipes was only 16min using a lift and a swivel socket.
I didn't get to do anything else because I did not have any stainless steel wire to weld the pipes because I switched over and decided to TIG weld it and the wire should deliver Monday or Tuesday.
Pics taken at K&D Auto 120 Paper Mill RD Suite C 30045
  #50
Old 09-19-2009, 05:35 PM
looks like a lot of work man, good luck with your project.
Your soldering skills could use some practice! Get a small pencil type iron for the wiring, these connections look scary
  #51
Old 09-19-2009, 05:40 PM
Andrei's Avatar
I know it looks pretty bad but the conductivity checks out.
and the best part is that the wiring harness didn't even need to be extended because it can be pulled out from under the car through the trunk floor. I just did it because of what Tim did on his sedan not knowing that^
but the good news is that the hard work has already been done. Welding and cutting pipes to fit is actually the easy part and the most fun.
  #52
Old 09-22-2009, 03:15 PM
Andrei's Avatar
350evo sway bar came today just in time. I reordered it on Sept the 3rd. This is a lot heavier compared to a stock one. I still want to use the stock 2nd gen sway bar since the suspension is still stock.
  #53
Old 10-11-2009, 08:38 PM
Andrei's Avatar
Pics taken at K&D Auto owned by Kenny @ 120 Paper Mill RD Lawrenceville GA 30046. 678-978-5373
The exhaust if finished and complete. Took a total of almost 50 hours of work and planning. All that remains is to polish it and get the bumper cutout and molded. I'll add more details later.
Gains through out the RPM range. No loss of torque that I noticed at low RPMs.
This is probably and most likely the worlds first quad tip dual 3" exhaust sedan.
  #54
Old 10-11-2009, 08:39 PM
Andrei's Avatar
  #55
Old 10-11-2009, 08:40 PM
Andrei's Avatar
  #56
Old 10-11-2009, 09:07 PM
Andrei's Avatar
Sounds a lot better after it gets warmed up. The car was down for over 2 days and that is the reason for the smoke at startup.
  #57
Old 10-11-2009, 09:35 PM
2003 Infiniti G35 Coupe
Sounds very raspy, I want to hear it wants its warmed up.. Other than that it sounds mean as hell. I love purr it makes.. Props for you, nice work!
Just wonering, why dual 3 inch? Are you going FI?
__________________
DO SOMETHING ABOUT IT!
  #58
Old 10-12-2009, 02:43 PM
Andrei's Avatar
I plan to. I am at least 2+ years away since I have a lot of other supporting mods I need to get done first.
  #59
Old 10-13-2009, 02:29 AM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Wow! Awesome work with all the pics. I wish I would have taken so many over the life of my car's build.
I would almost consider doing a temp crossover pipe and making one of the mufflers for looks until you go FI. Right now I would be willing to bet you are loosing power with that large of an exhaust on an N/A VQ.
__________________
ONE FUN SEDAN!! MY CAR (LINK)
Detailed Image | Greddy Twin Turbo & Built Motor by UMS Tuning = 649whp/651wtq | Rotora (12/4pot) | IForged | Quad Projector Retro | 1-off Dual 3", Dual Muffler Turbo-back Exhaust by Nichols AutoFab | NITTO | SPARCO |
  #60
Old 10-13-2009, 04:52 AM
Andrei's Avatar
To me it feels better than before. The car does sound funny at idle since there so much room and no back pressure. It pulls a lot stronger than before especially at 5k+ RPMs.
BTW did you noticed when you were doing the exhaust on your car that the car is not symmetrical after the drive shaft. And one drive shaft is longer than the other and the spare tire well is offset to the right side. I have about half an inch of clearance with that muffler on the right side from the spare tire well. Cant use a heat shield. Have to use thermal tape.
Tags
andrei, catback, combo, coupe, driver, exhaust, forum, g35, g35driver, infiniti, kinetix, megan, racing, sedan, v, video
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
