indepth peek at the mjmotorsports/dm2 intake manifold
Old Dec 5, 2010 | 03:55 PM
rpm06g35's Avatar
Well several people have asked so i will add pics and narrate as i go. Hopefully this will help everyone if they decide to try and go this route. Talk soon guys
new top that was to be dsskyline before he backed out
ernests top
lil mike/marvins top
erics top (only one running modified rev up collector)
the original top that started it all
milled top of non rev up lower collector
milling a runner
Actually removing the top here. Milling was the most preventative way of reducing warp
decked and ported on left just decked on right
Old Dec 5, 2010 | 03:56 PM
rpm06g35's Avatar
Now for the down low on porting. By stuffing the ports you can get the layout dye to make your removal of bulk material marks
In pics 1 and 2 I am spraying the dye from the bottom
in pics 3 and 4 notice the vague dye marks
in pics 5,6 and 7 you can see i chased the vague dye imprint with a sharpie to maximize idetification for max removal
blue layout dye used
rough cut removal tool
in pics 10,11 and 12 the removal of bulk
finished with the final of a 400 paddle wheel
Thanks for checking out guys
Mike
Old Dec 5, 2010 | 06:50 PM
the_sedan's Avatar
oh wow. dyno of differences?
Old Dec 5, 2010 | 07:46 PM
rpm06g35's Avatar
Dyno is the worst enemy i will be dealing with on this thread, however i did dyno my car to 280hp yet settled on a 278 hp tune due to a better fuel curve. Mods on the car are as follows
Crawford headers
strup test pipes
hks hi p
utec
unorthodox pulley
255 walbro
idler pulley delete
Many people wanted a before and after, same day, same temp same everything. Problem is the dyno time would be 5 hrs. pre dyno, then install, consult bump, utech install then tune. Its all money and i actually ran this set up on my car with no u tec for about 6 months. After everything was said and done the car ran a 13.65 at 105ish and the next pass i snapped an axle. track temp that day was around 108 degrees in fl
Old Dec 5, 2010 | 08:38 PM
the_sedan's Avatar
you should do a stock car with and without it......thatd give the best ideas IMO. but it looks legit to me.
Old Dec 6, 2010 | 12:33 PM
idrive_MD's Avatar
that looks like some huge porting. nice work
Old Dec 7, 2010 | 12:36 AM
rpm06g35's Avatar
I know bro. There have been alot of offers. But it gets complicated. Ive lost several sets due to numerous dyno promises. But on another note to get the full potential out of the mass amount of volume it has, you need to get some kind of program. Normal idle on the vq35 is 750rpm after install of whole set up idle drops to 450rpm. Its not just a bolt and go deal.
Old Dec 7, 2010 | 12:57 PM
Dmattei32's Avatar
i'll post some pics of mine once im done polishing it right now me and mike installed the lower 2 peices for now and it made a world of a differance with that done alone cant wait to get the top done and on yet i been draging my feet with it lol just been busy i guess..
but once its on i'll post some pics and i will say this setup is well worth every penny!!
any one up here in the north east CT. area feel free to contact me i'll let you take it for a spin if ur interested..
later, Dave
Old Dec 17, 2010 | 12:52 PM
sexyrob's Avatar
looks great, I was happy making a little more than the Mrev2 with my mild porting / polishing. would love to see what this does. I know plenum porting is tricky. It's hard to keep high velocity and high flow rate.
Old Dec 21, 2010 | 11:54 AM
Dmattei32's Avatar
Old Aug 27, 2011 | 02:45 PM
MikeGrote's Avatar
wow, very nice. what are you expecting the upper plenum to do to the lower to midrange power? looks great
Old Aug 31, 2011 | 09:49 PM
funnyscreenname's Avatar
you're doing great work. everything looks great and very professional. the porting especially.
i read the whole thread but, were you saying that just the port work caused the idle to drop to 450rpms or did i miss something? i've had ported heads and manifolds before (granted not on a g) but, it never effected the idle from what i can remember. the only time i remember having a rough idle was after cam install but, i got an safc and got it tune to where you couldn't even feel the car running at idle.
do you plan on mass producing these or just doing it for you and friends? jw. anyway, keep up the good work.
Old Sep 3, 2011 | 11:07 AM
Dsskyline's Avatar
I have this intake the rpms drop when the top is added. I think because there is so much volume with the top.
I have mine without the top using a stock top and 1/2 spacer.
The car pulled hard in the upper rpms I plan on going back to the dyno with the big top after I add a few things.
Here are some pics of the modded lower collector next to my stock one and a before and after dyno. The only thing changed was lower plenum, collector and changing from a 5/16 to 1/2 spacer.
I ran my PB of 13.147 with the 250hp tune.
Old Sep 11, 2011 | 09:19 PM
rpm06g35's Avatar
Thanks for posting up d mike
Old Nov 3, 2011 | 03:23 AM
bikinilust's Avatar
Subscribed
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
vamarris
Sep 26, 2015 12:56 PM
