Raspy Exhaust
Old 02-22-2017, 04:38 PM
parapraxis24's Avatar
Raspy Exhaust
I picked up my V35 Coupe 6MT about three weeks ago, and noticed when giving it the beans it has what I thought was a heat shield rattle. However, when I was getting new tires put on (my friend works at the shop) I was in the bay looking underneath my car and discovered that it has BERK cats installed. I knew it already had a Borla exhaust on there but the HFCs was news to me. The PO also had an X-Pipe welded in where I think the stock Y-Pipe used to live.
After a bit of reading, it appears that it isn't a rattle after all (Pretty sure the OEM heat shielding had been removed completely as well) but rather from the BERK cats.
Is there anything I can do? It's really annoying during hard acceleration to hear that rattle/raspy noise.
Old 02-22-2017, 05:31 PM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
Motordyneengieering.com
Old 02-22-2017, 08:04 PM
And what exactly am I looking for?
Old 02-23-2017, 08:27 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
ART pipes.
Berk HFC's have a bad rep on here for prematurely failing. The ceramic substrate material in the cats will break apart, reducing efficiency and causing all kinds of noise issues one of which is a rattling sound. Also the OEM cats had the heat shields on them and when they were removed you no longer had any shielding down there.......
Old 02-23-2017, 09:37 AM
ART pipes.
Ok thanks. As for heat shielding, I meant for the entire exhaust not just the stock cats.
Old 02-23-2017, 10:41 AM
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
With the Borla exhaust (sucks) the y-pipe should be long gone, the x-pipe is blending the volume from each bank! The previous owner was trying to get rid of the rasp with the x-pipe. I suggest you get your G back on the rack, with see if your exhaust is touching anywhere. Berk HFC are what caused my rattle, most obvious at idle! Happened to me after 8 months, called Berks told them about the rattle got no answers! A few months later I called again and my warranty had run out, was told I was SOL! Replace with Fast Intention HFCs, that's what I've been running since or Motordynes ART pipes either one might eliminate the dreaded rattle/rasp!
Gary
Old 04-08-2017, 09:07 PM
RoboG's Avatar
1320 performance test pipes "stock exhaust"
Hi guys, new to this site and trying to join the family, my question is should I be having any bogging down during high speeds? I hit the freeway after they were installed and the car bogged down around *************
idk it was wierd almost like if I was running out of gas or something lol
help?
Thanks G family
Last edited by Blue Dream; 04-09-2017 at 01:30 AM. Reason: Discussion of street racing/unsafe driving is prohibited
Old 04-09-2017, 07:40 PM
Scottwax's Avatar
6 speed G35 sedan
Bad cats will choke the engine off at higher rpm.
Old 04-09-2017, 11:35 PM
RoboG's Avatar
Bad cats
But it started doing it once I began running test pipes, my old cats had a bad heat shields
Old 04-10-2017, 09:33 PM
Scottwax's Avatar
6 speed G35 sedan
Did you reset the ECU? Or it could be something else that coincidently popped up after adding the test pipes.
The cat substrate acts like a resonator and kills the rasp. Remove them and instant rasp. Common on Honda V6 engines too. The pre-cat deletes make similar power gains to test pipes on the G, and also make the exhaust raspy. The solution is to add an additional resonator.
Old 02-19-2018, 12:19 AM
Raymond Sanche's Avatar
Raspy/Exhaust buzz
So bad heat shield can be the culprit to raspy/tin can sound coming from high acceleration??? Bad CATs?? Sounds like bad rice burner/Exhaust on my 2008 G35x. I can' stand the sound but also dont want to spend money where not needed. Thanks G fam!
