DIY: Front Bumper Replacement
I just posted this up on gShack, and wanted to share it with you guys as well. Larger images are available there.
Tools required:
Parts required:
Nissan OEM bumper, part # 62022-JK22H. For paint colors, please refer to this chart.
This is a sports bumper with the ICC cut-out, you can use the regular sport bumper and make the cut-out yourself.
Miscellaneous clips, as needed and shown. I re-used those from the old bumper.
Steps:
1. Your bumper will come unpainted a dark gray (plastic), unbox and stuff it in your car - if you go through the front passenger side door opening, you can fit it lengthwise to the back of the car with no problem.
2. Remove your front bumper. I did not document this as it’s fairly easy, but you can refer to this DIY from Q8y_drifter.
3. If your car is lowered, or you want more room, it helps to jack-up the front end of the car. Be sure to support it well, i have jack stands on the side-rails and kept the lift on the front jacking point.
4. On the old bumper you just removed, set it down and remove the “threaded” clips on the bottom. Two types of clips are shown here, you may have one or the other (or both), both are fairly easy to remove with the help of a small flathead screwdriver to remove the tension holding it to the bumper.
5. If you have ICC, do this, otherwise skip to step 6.
Remove the three screws as shown, then unclip where pointed. This is a two-piece assembly, the front comes out from the front of the bumper, what you’re looking at is the rear portion. The front, and rear, sandwiches the bumper in-between.
6. On the top-side of the bumper, remove these two bolts. Remove the metal mounting reinforcement/bar and set-aside.
7. Remove the top rubber strip running the length of the top-side of the bumper. The tabs holding them down are wider on the bottom so you’ll have to squeeze them with a needle nose pliers, if you just pull from the heads, they will break.
8. Remove the two metal mounting bars on the middle part of the bumper, these are located on each end of the bumper, the area that attaches it to the fenders. The tabs that hold them in place are rather difficult to remove as they’re ribbed. You do not want to pull from the top head or they’ll break. What i did was insert two screwdrivers for leverage and slowly pushed one up, the other down and vice versa until the bar came off.
9. Comparison of old vs. new
10. Now attach everything you removed from the old bumper onto the new bumper by following these steps in reverse (or however way you want to do it).
A local shop wanted 2.75 hrs. of labor to install the bumper. I did it in roughly 1.5.
Have fun!
Tools required:
- 10 mm socket wrench and extension
- Small flathead screwdriver
- Long-nose pliers
- (Optional) A couple other screwdrivers, any will do
Parts required:
Steps:
Have fun!
Welcome and thanks
I don't have measurements, but it's fairly huge. Imagine the bumper by itself plus about 6-10" of padding all around -- top, bottom, sides, front and back. The box itself was shaped like a bumper, one straight and two angled boxes. It wouldn't fit in the car for sure. It was delivered via FedEx Freight (not by your typical FedEx truck neither).
That's all i've got, sorry.
rezendvous420
05-31-2020 01:26 PM
Luisgalvan33
07-19-2018 08:16 PM
st33zygill
07-29-2015 10:05 PM
