Problem removing center console
Originally Posted by Wes_888
Sorry if this is a dumb question.. but do I put the car in neutral/drive first then turn the car off?
Or
When the car is already off... then do I put the car in neutral/drive to remove the paneL?
thanks
Or
thanks
When removing the shifter console and the center panel console, do they just come off? Or are there any electrical attachments that are connected to it?
what is the function of the shift lock anyway?
The shifter cover has a wire harness connected to it which is easily removed. The shifter console comes out from the back side FIRST because it has hooks in the front.
Originally Posted by terrycs
The shift lock alllows you to move the shifter handle without turning on your car. Typically used for towing with rear wheels on the ground.
K, remove wire harness. Gotcha.
Thanks for the replies terry. I really appreciate it.
on
So will I have to press on this shift lock first before I can move the shifter while the car is turned off?
Originally Posted by kool-aid
i just pushed the start button twice without applying the brakes (well obviously set the parking brake) that will allow you the shift into neutral/drive
StreetStandard
Engine-Vendor
117
05-22-2020 08:21 AM
