2nd Gen (V36) Sedan All 2nd Generation (V36) Sedan Classifieds
FS: G35 Sedan SPC Rear Camber and/or toe bolts... same as Eibach
Old May 19, 2011 | 08:15 PM
rkim210's Avatar
I have 1 set of rear camber and/or toe bolts brand new. You only need one set per car (I found out the hard way with the misleading tire-rack stating "1 kit per wheel). Anywho.. I didn't know the eibach camber kit I ordered came with it, so I have 1 brand new set of this.
Same as Eibach part 5.72265K
I confirmed with Eibach they use SPC parts, and just box it with Eibach boxes... what a way to make extra dough.
$30.. shipped.
Attached Thumbnails G35 Sedan SPC Rear Camber and/or toe bolts... same as Eibach-img_0031.jpg   G35 Sedan SPC Rear Camber and/or toe bolts... same as Eibach-img_0032.jpg   G35 Sedan SPC Rear Camber and/or toe bolts... same as Eibach-img_0033.jpg
Old Jun 7, 2011 | 12:45 PM
G35xLikeWhoa's Avatar
How do these work? Are they just replacement bolts for already Eibach camber/toe or do these just go over the OEM camber/toe to help adjust the alignment? Thanks.
Old Jun 7, 2011 | 02:56 PM
rkim210's Avatar
Thumbs up
These are replacement bolts that are longer that the stock ones. You willl have to get the toe hole elongated in order for the bolt to fit and work.
My toe was off by 1.9 degrees, and it fixed it. Definitely worth it instead of paying for tires every 8 months.
Old Jun 7, 2011 | 03:11 PM
Oh, i see..
So the only difference between this and the whole (spc/eibach) camber and toe adjustment kit (arm) is that with this, i have to elongate the toe hole to make it fit? Whereas if i bought the whole camber kit i wouldn't need too.. correct?
Sorry bout all the questions, I just lowered my car over the weekend and i'm trying to figure out the best solution to take care of the camber/alignment issue.
Old Jun 7, 2011 | 04:34 PM
rkim210's Avatar
Oh, i see..
The Eibach camber kit comes with the following:
-2 camber arms
-2 toe bolts
Depending on how much you lowered the car, you might need both.
I put coilovers on mine, and dropped it about 2.5 inches in the front, and 2.25 inches in the back.
I first put the camber arms in, but when I fixed the camber back to normal, the toe was facing outwards, and the oem toe bolt was maxed out.
That's when I got this toe kit. My car is in perfect alignment now.
The Eibach camber kit should come with both the arms and the toe bolts. You'll need to elongate the holes should you use the toe bolts.
Old Jun 8, 2011 | 09:12 AM
ker-egg's Avatar
You have PM. I would like a set.
Old Jun 13, 2011 | 01:26 PM
rkim210's Avatar
One set left! Thanks!
Old Jun 13, 2011 | 09:50 PM
RhiNoKiLL's Avatar
one set = both rear wheels right?
and these are camber arms with toe bolts?
pm me ur paypal please
RhiNoKiLL's Avatar
Old Jun 14, 2011 | 09:43 AM
ker-egg's Avatar
Thanks for the toe bolts!
Old Jun 14, 2011 | 06:49 PM
rkim210's Avatar
One set = Both rear wheels.
These are toe bolts only. The rear camber arms I don't have for sale.
Old Jun 23, 2011 | 07:02 PM
P10 WRC's Avatar
what do these normally cost?
Old Jun 24, 2011 | 02:05 PM
rkim210's Avatar
They're like $35 or something like that. Tire rack has them up for $31 and change shipped now.
Old Jul 28, 2011 | 12:46 PM
rkim210's Avatar
1 set left.
Old Jul 28, 2011 | 03:55 PM
zoop425's Avatar
what camber kit did you get? I cant figure out which one I need.. I want one with the camber arms and toe bolts.. dont mean to take over the thread.
