Infinty Kappa VQ sub
Old Feb 13, 2007 | 11:31 PM
pch2005's Avatar
I have a brand new Infinity Kappa Perfect 12 inch sub for sale. Want 200 for it...
Let me know what's up
Here goes a link for more info
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA+PERFECT12VQ'&Ser=KPE&Ca t=SUB
Power Handling, RMS: 400 Watts
Power Handling, Peak: 1600 Watts
Sensitivity: 89dB
Frequency Response (±3dB): 25Hz - 400Hz
Mounting Depth: 7"
Impedance: 4 Ohms
Variable Q (patent pending)- Kappa Perfect VQ Series subwoofers provide a patent-pending approach to adjusting Q. Kappa Perfect VQ woofers allow motor strength to be be varied using supplied polepiece inserts. Q adjustments allow the woofer to be optimized for a particular enclosure or application and provide the user with exceptional performance for several applications in a single enclosure.
Proprietary die-cast frame - This frame offers amplie rigidity to support the motor structure, and its vented architecture provides greater movement of air behind the cone and spider for maximum cooling.
Magnesium Metal Matrix (M3D) woofer cones - This material is 20 times deader that aluminum, delivering superior stiffness and damping as compared to traditional cone materials.
Spider-integrated tinsel leads - These enhance reliability and eliminate audible tinsel lead slap.
Nitrile-butylene-rubber one-piece surround and gasket - This material provides an optimum blend of elasticity and internal damping. The large roll offers good long-throw linearity with the proper amount of control and stability at excursion limits.
Vented polepices - These provide additional cooling to the motor structure. The subwoofer's thermal capabilities are augmented, thus increasing power handling.
lucidazn
Dec 29, 2004 04:17 PM
JimHarrison
Aug 28, 2004 11:18 AM
gdupg35
Oct 21, 2003 03:14 PM
