FS: motordyne throttle body bypass
Old May 12, 2007 | 08:51 AM
UFGatorG35's Avatar
Let me try this again with the correct description ;-)
I bought this for the hell of it and never installed it. It was going to go on an 05 6MT, and should fit most Gs. Helps keep the throttle body cooler, thus keeping the air cooler going into the plenum.
Please dont ask "will it fit my 0x coupe/sedan/auto", I have no idea but think the throttle body is pretty standard.
$70 shipped within the CONUS. PM me if interested.
Old May 12, 2007 | 09:19 AM
g35man04's Avatar
CLUB MODERATOR
i have this on my car and it does work! I have an 04. I know that it fits 03-05...all you do is splice it into the cooling line into the bottom side of the throttle body. takes about 10-15 min to do this mod! you can control on or off with it...
Old May 12, 2007 | 09:28 AM
g35rcr's Avatar
no this one is the throttle body bypass plate....copper iso thermal kit...this one is a solid plate between the throttle body and upper plenum opening
Old May 12, 2007 | 09:34 AM
g35man04's Avatar
CLUB MODERATOR
ohh....i have the MD iso thermal 1/2 spacer with the iso gasket in between lower and upper plenum then i have the coolant bypass mod...where you can control whether or not coolant goes into the throttle body....
OP-can you post a pic of it?
Old May 12, 2007 | 10:08 AM
g35man04's Avatar
CLUB MODERATOR
Old May 12, 2007 | 12:15 PM
g35rcr's Avatar
yeah there is that one and then there is one that is a copper plate that has a coolant line bent into it
Old May 12, 2007 | 12:21 PM
g35man04's Avatar
CLUB MODERATOR
so whats the benefit of that then?
Old May 14, 2007 | 02:22 PM
Dieselnuts's Avatar
This is the description I pulled from the motordyne website:
Compatible with any type of plenum stock or modified and compatible with any type of weather hot or cold. Copper Iso Thermal also reduces heat transfer into the upper and lower plenum assembly, but the Copper Throttle Body Heater keeps the throttle body heated to prevent ice formation on the throttle body valve on very cold or snowy days. If it snows in your area use the Copper Iso Thermal to keep the TB heated while still take full advantage of the cold dense air for increased HP.
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
hrdwirk1
Oct 2, 2015 06:34 PM
NyCrAzY
Oct 1, 2015 09:19 AM
