F/S: ALPINE 12'' Type X
Old Sep 22, 2007 | 01:05 AM
TIAN's Avatar
Hold The Line
I had big plans for this sub but I need to let it go to someone whos gonna put it to work. It brand spankin new! I took it out the box once to bask in its glory This sub is in mint condition fellas! SOLD
SPECS:
Frequency Response: 24Hz - 200Hz
Peak Power Handling: 3000 Watts
RMS Power Handling: 1000 Wat
Power Range: 500 - 1000 Watts
These bad boys retail for $500 big ones.
I am open to reasonable offers... no lowballers please
LINK to ALPINE:
http://www.alpine-usa.com/US-en/prod...&lang=en&tab=F
Old Sep 22, 2007 | 01:56 AM
d4vid's Avatar
ONE DOLLAR!!!!! j/p!! Nice sub good luck!!!
Old Sep 25, 2007 | 03:34 PM
TIAN's Avatar
Hold The Line
BUMP for an awesome sub
Old Oct 3, 2007 | 12:27 PM
TIAN's Avatar
Hold The Line
ttt
Old Oct 3, 2007 | 06:23 PM
TIAN's Avatar
Hold The Line
FEATURES (1 12'' SUBWOOFER)
Gasket
• Design: Concealed Mount Design with Front/Rear Sealing Gaskets
Tinsel Leads
• Design: Reinforced Layer Spider Integration (Patent #6,810,988)
Terminals
• Design: Insert Terminal Blocks with High Current Voice Coil Configuration Jumper
• Layout: One Side
Frame
• Design: Perimeter Vented Exo-Frame (Patent Pending) with Integrated Spider Landing (Patent #6,678,387)
• Material: Cast Aluminum
Motor Structure
• Configuration: Billet Copper Shorting Sleeves with Heat Dissipation Plate (Patent Pending)
• Pole Geometry: Compound Radius Curve (Patent #6,639,993) with T-Drive
Voice Coil
• Design: 6-Layer 4Ω Voice Coil with Inner/Outer Winding
• Material: 220°C Aluminum Wire on Twin-Wall Aluminum Former (Patent #6,292,079)
Spider
• Design: Mirrored Progressive
• Material: Nomex®
Surround
• Design: High Amplitude Multi-Roll (Patent Pending)
• Material: Injection Molded Santoprene®
Diaphram
• Design: 1-Piece Parabolic wtih Vented Force Transfer Assembly
• Material: Kevlar Rohacell® Layered Composite
KruZZe
Feb 27, 2023 05:04 PM
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Frankieg35
Oct 7, 2015 10:22 AM
