will four 20s fit INSIDE g.coupe w passenger?
lol.
i know this is out of place but itll prob get the best response here
im going to buy 20s and prob wont have another car to put them in.
will they fit in the car with a driver and passanger?
i also have a empty trunk. (with spare)
maybe 2 in the trunk 2 in the backseats?
help!!
t.i.a.
help!!
t.i.a.
haha not with another passenger man....if they are in boxes good luck..I put 4 20" tires in my coupe but without a passenger and it was crammed full.....couldnt see anything....your truck is only big enough for one tire because of the way its built....you cant bend a rim to get it in...you will have to lay the back seat down and see if you can push it through the back opening..you may get lucky.
I fit 4 18's w/tires in the back seats. it was a bit crampe, but it worked. you have to place them like this [][][][] no boxes. just wrap them in plastic garbage bags
18x9 tires 255.45.18 all around, and i still had a bit room. i'm sure i could have done it with 20 w/tires
yeah not a chance in hell haha
maybe if you take everything out of your trunk, you Might be able to fit 2 in there, you dont have any friends with bigger cars or a truck?
are there tires on them?
why risk it? kick the other person out.
If the 20s are without tires, it will fit easily. When i bought my 20s i fit all in my car with the boxes, and never even used the passenger seat. Put one front rim in the trunk (the smaller rim). The other 3 fit in the backseat. 1 behind driver seat and two behind passanger seat. Passenger seat will have to be pushed up a little bit
all that sounds like way too much trouble...playing tetris with rims and tires! Thats why we have friends...so they can carry 2 rims with tires in their coupe while you take the other 2. Problem solved.
probably could fit. i was able to fit 4 19"tires (no wheels on) in my coupe. one in the trunk and 3 in the back seats with the back seat down. the passenger better be short though cuz i don't think there was a lot of leg room.
Micale757
Lighting
Apr 8, 2020 10:46 AM
Mick_L
Aug 25, 2015 04:27 PM
