FS: Everything you need for Manual 6mt Swap
Old Dec 31, 2008 | 01:50 PM
ModMe's Avatar
Hi,
I purchased all these parts from an auto parts store with the intention of doing a manual swap. However, I'm getting very busy with school and do not have the time to do this. This would be very valuable for someone that wants to do the manual conversion. I have done the research and bought all the parts, even the small bolts and brackets, that you need for the complete swap. All parts came out of a 2005 G35 coupe with 5000 miles. I have a receipt showing this. Here is a list of all the parts included:
-Manual transmission CD009 Code (Latest version)
-Transmission mount
-Shifter
-Shifter Trim
-Drive shaft
-Clutch disk with alignment tool
-Flywheel
-Pressure plate
-Clutch Mastery cylinder w/reservoir
-Clutch slave
-Clutch entire tubing
-Clutch pedal
-Brake Pedal
-Entire Engine harness
-Engine ECU
-Interior Center Console (2005 version)
-Center Console Flooring
-Speedometer/ Gauge Cluster (with Navi)
-VLSD Rear Final Drive Differential
-All necessary Brackets and
I probably forgot to list some of the parts but I can assure you that every part needed is included. I'm willing to part with all of the above for $2500. It's not a difficult project. Takes a DIYer about 2 days to complete. Thanks.
Jason
Old Jan 9, 2009 | 11:23 PM
sjcurtis's Avatar
Question Sedan or coupe
Is the swap for a sedan or a coupe? What color is the interior parts? And where are the parts located?
Old Jan 10, 2009 | 03:19 AM
ModMe's Avatar
This is for coupe and interior is black
Old Jan 13, 2009 | 01:34 AM
D&G35's Avatar
bump for a great product..i was originally gonna do this..g/l with the sale..
Old Jan 13, 2009 | 12:46 PM
ttrank's Avatar
Grocery getter
Wow, that is a good deal. The last guy I know who had one done cost him something like $9k.
Old Jan 13, 2009 | 01:15 PM
GreenGoblin's Avatar
The goblin resurrection
Wow that is nuts, good luck with the sale.
Old Jan 16, 2009 | 08:05 PM
rob808's Avatar
I wish i could do that but not too good with mechanical stuff. Maybe
Old Jan 19, 2009 | 07:10 AM
S E G A's Avatar
where are you located?
Old Jan 19, 2009 | 01:34 PM
ModMe's Avatar
los angeles, ca
Old Jan 19, 2009 | 05:12 PM
S E G A's Avatar
pm sent
Old Jan 19, 2009 | 05:16 PM
ShanesG's Avatar
Damn i waaaaaaant, god i wish i had a second car!
Old Jan 19, 2009 | 09:15 PM
tragedycat's Avatar
So are transmissions swaps already worked out pretty well or is this a tentative project kind of thing? Last I heard there were lots of glitches still with swapping out the transmission, related to some minor difference with auto engines? I may be remembering wrong though.
In any case, good luck with sale.
Old Feb 4, 2009 | 03:15 PM
EGGPLANT's Avatar
I want... But scared ill fudge something up....
Very handy with tools but idk....
Good luck with sale....
Old Feb 4, 2009 | 05:50 PM
teamspink20's Avatar
willing to part flywheel?
Old Feb 5, 2009 | 01:25 PM
llut5at's Avatar
I've seen a few transmissions on ebay running around $800, do these not come with all the necessary parts? also, will the coupe one fit on a sedan and lastly has anyone done this before?
Thanks
