FS: VQ35DE Rev-Up Engine Parts and Accessories
Old Sep 14, 2009 | 08:52 PM
G356MTBB's Avatar
FS: VQ35DE Rev-Up Engine Parts and Accessories PLUS MORE
All -
I have a complete VQ35DE Rev Up that I'm parting out. Right now everything is up for sale including internals such as:
Cylinder Heads
Valve Covers
Block
Front Cover
Timing Chains
Cams
Crank Shaft
All accessories are available as well (All have 11k miles):
A/C
P/S
Oil Pump (31k)
Alt
Flywheel (11k face looks fine)
Clutch (11k plenty of material left)
Complete Intake
Thottle Body
Why you ask? This engine had 31k miles on it with a Oil Consumption problem. According to Nissan/Infiniti this is related to the rings on the pistons. The block itself is sound.
So why wasn't it covered under warranty? Funny you should ask... Nissan/Infiniti likes to punish those of us that modify our cars with things such as intakes and exhausts... Ridiculous I know but that was my fate. I purchased a used engine with 11k miles on it and now I'm selling the unused accessories and other parts that I had duplicates. As we all know the parts are more valuable then an entire engine.
Right now I have one of everything so just ask if you need a specific part and we'll work a deal. I plan on getting things up on eBay as well but thought I'd try this first and see if there was any interest. As the parts are sold I will post them PM me with requests and I'll get back to you as soon as possible.
EDIT:
Also have a set of Brakes Front and Rear probably had about 20k miles on them before I upgraded
Full cat back exhaust (Stock) has about 5k miles on it
L/R Cats have approximately 15k miles on them
Extra lower plenum (stock) from MREV replacement had about 5k miles on it
Air box assy - Everything but the MAF sensor
UPDATED: Complete A/T engine harness
Also have a full set of Springs (front and rear)
I also have a "blown" IPDM and ECU, that was a stealership diagnosis but I understand it's VERY difficult to blow the IPDM and it's most likely a relay It's up for sale if anyone wants to work thru diag just make me an offer.
As you see below I don't have the starter to this motor.
SOLD:
Front Cover (Outer)
Block (Block only, still have pistons, rods, crankshaft and lower end available.)
Upper and Lower Oil Pan
Crankshaft
Crankshaft Girdle
Main Bearing Caps
Camshaft Sensors
Flywheel
Alternator + Bracket
Flywheel Bolts
Clutch Bolts
NEW:
Have a CD009 Transmission with 32,000. Whines a bit but works fine diagnosis is a main bearing which can be replaced. Make me an offer.
Old Sep 14, 2009 | 08:54 PM
Beebo's Avatar
Dude intake and exhaust wont cause oil consumption. Get a lawyer and fight
Old Sep 14, 2009 | 09:10 PM
xjonmo's Avatar
how much for the upper plenum shipped to 07458
Old Sep 14, 2009 | 09:23 PM
ttrank's Avatar
Grocery getter
Do you have the starter?
If so, how much shipped to 85085?
Thanks
Old Sep 15, 2009 | 02:17 AM
hi1mdav1d's Avatar
how much for complete intake shipped to 94501
Old Sep 15, 2009 | 09:01 PM
G356MTBB's Avatar
Are you looking for the air box to the throttle body? If so, I don't have it complete, I do have the air box but it does not have the MAF.
Old Sep 15, 2009 | 09:07 PM
G356MTBB's Avatar
Thanks
Sorry had to use the starter on my new engine.
Old Sep 15, 2009 | 09:09 PM
G356MTBB's Avatar
You know that, I know that... Nissan doesn't give a sh@t. Their pockets are slightly deeper than mine and I've already been through 4 months of battling with them. My next move is States Attorney Consumer Affairs Division.... Right now I'm trying to decide who to go after first. The dealership or Nissan.... What a PIA.
Old Sep 15, 2009 | 09:19 PM
G356MTBB's Avatar
$160 for the upper plenum (not including throttle body)
It will ship from 20871 and it weighs around 10 lbs. If you're interested pm me your full address, I'll get a more detailed shipping quote, fedex, ups, whatever, I'll run it and send it over to you. Shipping will be whatever it costs I won't add anything to it.
Old Sep 16, 2009 | 02:45 PM
eZg's Avatar
eZg
I could use the block......how much picked up?
Old Sep 16, 2009 | 06:30 PM
eZg's Avatar
eZg
Oh yea
In what city are you located?
Old Sep 16, 2009 | 06:58 PM
G356MTBB's Avatar
Shot you a PM
Old Sep 17, 2009 | 02:30 PM
JoeSage's Avatar
would you have enough clutch parts to do a tranny swap from auto to manual? if so how much for it all?
Old Sep 17, 2009 | 03:52 PM
code2424's Avatar
Hey in your signature says you got ztube, you selling that by any chance?
Old Sep 17, 2009 | 04:34 PM
G356MTBB's Avatar
You would need a M/T wiring harness (I don't have that)
Tranny (don't have that)
Clutch and new flywheel (do have both)
plus the center console and shifter, removal of your A/T computer and a reflash of the ECU. That's a big job!
In summary, no, I just have the clutch and flywheel.
