FS: Complete 2006 OEM Brake System
I put on a complete set of Brembos so the OEMs have to go. A great upgrade if you have the smaller 03'-04' brakes, which was one of the biggest complaints about the early models. From a 2006 coupe with 25k miles.
Front 2 piston calipers, 12.6 inch diameter rotors
Rear 1 piston, 12.1 inch diameter rotors
All 4 rotors turned (and within specs.)
Front pads 0.3 inches
Rear pads 0.2 inches
Complete set of brake lines.
Mounting bolts included.
All you need is some brake fluid.
$500.00 plus shipping using Paypal or $425 locally in Atlanta (cash).
PM if you are interested.
^^ I think you have those already. ![Dunno](https://g35driver.com/forums/images/smilies/dunno.gif)
'05+ Sedan and Coupe, '06 Sedan X
Front: 12.6-inch X 1.1-inch power-assisted vented disc - 2 pistons
Rear: 12.1-inch X .63-inch power-assisted vented disc - 1 piston
Good upgrade for 03/04, though.
Yes, everything is included. All brackets, bolts, brake lines, pads, shims, calipers, rotors, and pads. Great upgrade (assuming you are an automatic coupe with the small brakes?)
on
this upgrade will fit all models from 03-pre june 05 models this is a simple plug and play upgrade i have done this already but what you will have to do is either A, take off the brake dust shield or cut it like i did to mine ![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
but this will fit
but this will fit
