does anyone have pics of subs in their coupe
Old Oct 16, 2003 | 12:21 AM
  #31
limeg35's Avatar
Re: does anyone have pics of subs in their coupe
pic
03 coupe 5AT DG/G premium,performance
Old Oct 17, 2003 | 02:09 AM
  #32
nyckid's Avatar
i cant even fit my 12" sub in my coupe, the trunk is way too small
Old Oct 21, 2003 | 06:35 PM
  #33
IslandBwoy23's Avatar
[img]C:\Documents and Settings\Andrew Roberts\My Documents\My Pictures\dsc01705 (small).jpg[/img]
[img]C:\Documents and Settings\Andrew Roberts\My Documents\My Pictures\dsc01700 (small).jpg[/img]
[img]C:\Documents and Settings\Andrew Roberts\My Documents\My Pictures\dsc01701 (small).jpg[/img]
[img]C:\Documents and Settings\Andrew Roberts\My Documents\My Pictures\dsc01702 (small).jpg[/img]
[img]C:\Documents and Settings\Andrew Roberts\My Documents\My Pictures\dsc01703 (small).jpg[/img]
[img]C:\Documents and Settings\Andrew Roberts\My Documents\My Pictures\dsc01704 (small).jpg[/img]
-Andrew G35c 6MT
Old Oct 21, 2003 | 10:13 PM
  #34
cram's Avatar
A few pics of an Infinity Basslink install
Basslink Install
Craig Ramseur
03.5 G35C/BlkOb/
Graphite/5AT/Bose/Alpine/17"/
Z-Xtreme Grounding/AutoVation Alum Pedals
vroom vroom
Old Nov 22, 2003 | 02:26 AM
  #35
JAG35CP's Avatar
here
Old Nov 22, 2003 | 02:27 AM
  #36
JAG35CP's Avatar
again
Old Nov 22, 2003 | 02:28 AM
  #37
JAG35CP's Avatar
and again
Old Nov 22, 2003 | 02:31 AM
  #38
JAG35CP's Avatar
tire before
Old Nov 22, 2003 | 02:33 AM
  #39
JAG35CP's Avatar
tire after
Old Nov 24, 2003 | 01:53 PM
  #40
weslutes's Avatar
Why waste the whole trunk?with those systems you need way too much equipment. My 12" image dynamics sub & 250/1 JL amp uses way less power and is easy to remove if needed,not only that but it hits hard enough to hurt my ears if i turn it all the way up.
Dark Side Of The Moon
Old Nov 24, 2003 | 01:58 PM
  #41
paintballbitch's Avatar
hey there
How much did you pay for the enclosure?
Thanks!!!
Old Nov 24, 2003 | 02:50 PM
  #42
weslutes's Avatar
My friend makes custom boxes,I payed $800 for all parts and labor.the 250/1JL amp I got has an adjustable *** i had him put in the center console.
Old Nov 24, 2003 | 03:36 PM
  #43
aorbeta's Avatar
weslutes,
Does the entire enclosure sit above the carpet? Or does some of the box extend down into the area below, where the stock amp and XM receiver would be?
-Alan
Old Nov 25, 2003 | 03:32 PM
  #44
weslutes's Avatar
The sub is completely removable and is held in place by one sided velcro on the bottom. No alterations or fabrications were done to the car. The amp can be placed anywhere.I wanted a system as simple as possible that would not drain my battery.this system only consists of a box+12",an amp,a fuse,and wires.Most systems need many other items due to lack of power and will drain your battery.
Old Feb 10, 2004 | 04:41 PM
  #45
G35abadiguard's Avatar
I know this is only for coupes.. but a G35 is a G35 ... so i wanted to share mine with you guys..
| Black | Willow | 20% Tints | Clear Corners | 12" Kickers CompVR | Bazooka EL1500 | Customized "AbadiGuard" Floor Mats |
